08-11-2016, 16:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | S6 clone G9200 mt6572 hang after format, nead to fix ! Code: Chinese Miracle II [MTK module] v 1.54 Operation : Check / Read Info [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x6ADE9514831E95E3EF3676D9D6D8BB6C INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done :( Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:08 i nead a firmware to fix it, i found about ten flash file, but no one work, plz nead the flash file to fix , or its name. thanks |
08-11-2016, 19:52 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Duelog, seems, PMT damaged by pity tool format. Without reading phone initial info it is near zero chance find correct fw except bruteforce method - try one by one. |
08-11-2016, 20:01 | #3 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
i managed to get this with merapi: Code: Manufacturer: alps Phone Model: SM-G9200 CPU Model: mtk6589_wet_lca Phone Version: 5.0.2 IMEI: NULL what is brute force methode ? thanks | |
08-11-2016, 21:09 | #4 (permalink) |
Member: 96141 Status: Offline Thanks Meter: 200 | i have flash it back wuth its own volcano backup, then i readed the flash by CM2 now: Code: Operation : Read Flash [ v1.54 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 12 ] Sync... 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : 0x6ADE9514831E95E3EF3676D9D6D8BB6C INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_benrui72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT6572 / V1.1.1 / benrui72_wet_lca / NAND FW Size : 343 MiB Brand : alps ProdName : benrui72_wet_lca ProdModel : benrui72_wet_lca Device : benrui72_wet_lca AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.8 Android Info saved Scatter saved to : C:\Users\Bono\Desktop\MT6572_NAND_alps__benrui72_wet_lca__benrui72_wet_lca__4.2.2__ALPS.JB3.MP.V1.8 Done! Elapsed: 00:03:18 Reconnect Power/Cable! so ? have i now enough info to searsh for my original firmware ? br |
