06-26-2010, 10:06 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: The Land Of Promise
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | s621 unlock problem always error i try to flash again with the backup its continue flashing but phone cant power on i try to format with complete mode i can get this error Code: COM6 [VCP0] selected module v3.44 Device: Alcatel-S621X, S621A Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:5603:A006 status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22442200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22442200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 01020000/00FE0000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35198902010835 flash: 01227E22442200:FFFFFF00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:FFFFFF00000000 error: wrong erase first sector at 0x01020000 error: format ffs failed Finalization Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A__system_log_20100626-165753.B0X.bin Finished, time used: 28 sec Remove/Install battery now ! any body can help me |
06-27-2010, 03:17 | #6 (permalink) |
Member: 857401 Status: Offline Sonork: 1596086 Thanks Meter: 129 | i tick repair security area but failed to format Code: original imei: 35198902010835 flash: 01227E22442200:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 01227E22442200:18E59F00000000 error: wrong erase first sector at 0x01020000 error: format ffs failed Finalization Fail file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-S621X,S621A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP1_V34__system_log_7236F8A3_DF65B65F_20100627-101502.B0X.bin Finished, time used: 1 min 47 sec Remove/Install battery now ! pls help me |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
