11-29-2008, 01:19 | #1 (permalink) |
Insane Poster Join Date: Aug 2007
Member: 572230 Status: Offline Thanks Meter: 5 | How to Change Language?? I have searched many posts and still be clueless. Infinity-box is very different than other box. Anyway, I have a LG KE970 and want to add Chinese language support. What I usually did is simply flash a Chinese KE970 firmware. The problem is I am not which firmware in support area has Chinese. So I just tried one by one, then the phone can't power on after I flash it. I revived the phone by some free gsm flash tool. But I really want to know how to use infinity-box, after all, I paid $200 something for it. I read some post discuss the language pack editor that is really cool tool. Then when I try to open it, it ask for higher activation level. Hum.... so I can't change language unless I pay more? Or, I just doing the wrong way? Somebody please kindly guide me. Any link, post or a instruction will be appreciate. I did read the documentations, but that confuse me more, since there are too many models list over there. Also, I am glad to see that Infinity support cect a008, but I cant find a flash file in support area. My question is: How to correctly flash KE970 How to change Language into chinese for KE970 How to change Language into chinese for Cect a008 Thank you all |
11-29-2008, 01:46 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I think you have started from wrong point. I suggest you to start your search from your own HDD: C:\Program Files\InfinityBox\Documentation Answer #1: How to write flash (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to unlock (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (step-by-step instruction): 1. connect cable 2. run "Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Reset" or "Format" button and follow instruction given by software Answer #2: Flash phone with firmware with Chinese language. You can see files description in support area: \flashfiles\LG\Language_pack_description.txt But as I can remember there is no files with Chinese language in support area, so here is an instruction what to do: C:\Program Files\InfinityBox\Documentation\FAQ\How_to_get_latest_flash_files_and_new_languag es.txt Answer #3: You can get more information about software here: http://www.infinity-box.biz/index.php?id=langedit&lg=en You can check current status of Infinity-Box Language Pack Editor software tests here: http://forum.gsmhosting.com/vbb/showthread.php?t=475453 http://forum.gsmhosting.com/vbb/showthread.php?t=483338 If you have found that this software cover all your requirements and if you are ready to buy copy of Infinity-Box Language Pack Editor you are welcome to contact to nearest reseller from the next lists: http://www.infinity-box.biz/index.php?id=howtobuy http://www.infinity-box.com/dealers.php You can contact to our sales person directly via e-mail: [email protected] or [email protected] or by ICQ: 21260138 Do not hesitate to contact us if you will have more questions. |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
12-22-2008, 01:46 | #3 (permalink) |
Member: 572230 Status: Offline Thanks Meter: 5 | Thanks for the reply. I finally found a Chinese KE970 and read out the firmware. But the size is more than 20MB which can't be accepted by Gmail. Is there a another way to send you guys the firmware? thank you. |
12-30-2008, 02:27 | #7 (permalink) |
Member: 572230 Status: Offline Thanks Meter: 5 | Download KE970P40_ESA-V10g_000-00.B1M.bin from support site. Flash log: COM35 [VCP0] selected Device: LG-KE970 Checking data, wait... Action: flash write Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... backup critical area Done Check memory... Check memory Done Write... reset... done Writing: Firmware Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 1214 sec After flash language remain same check firmware with read information: Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KE970P40FL-44-V10c-234-30 APR 27 2007+1 imei: 354xxxxxxxxxxxx Done Finished the software version still v10c Should I flash FFS-2/File system or eeprom also? Where can I find the FFS-2 flash file? Which part I did wrong? I just want Chinese in KE970 |
03-01-2009, 22:14 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Are you sure that you have read flash backup from phone that had Chinese language ? What languages was in your phone before flash ? What languages you can see in phone after flash ? What was original phone firmware version ? |
03-03-2009, 04:33 | #12 (permalink) |
Member: 572230 Status: Offline Thanks Meter: 5 | Yeah, I follow the procedure in documation. The phone has english and other non-chinese language, (Sorry, it has been a while, kinda forget what language exactly) After flash, everything stay the same. Check firmware version remain unchanged. So the original firmware was KE970P40FL-44-V10c-234-30 Thank you for the help |
03-03-2009, 16:50 | #14 (permalink) | |
You can flash phone with firmware with Urdu language or you can try to add new language in firmware by yourself. You can get more information about software here: http://www.infinity-box.biz/index.php?id=langedit&lg=en You can check current status of Infinity-Box Language Pack Editor software tests here: http:///vbb/showthread.php?t=475453 http:///vbb/showthread.php?t=483338 | |
How to change language to English in U8138 | tical | LG | 5 | 07-26-2005 18:32 |
how to change language to t100 | Legionaru | Sony Ericsson | 1 | 08-25-2004 14:47 |
how to change language to English... | masterross | VLSI, Conexant, Skyworks and Old Models | 6 | 06-28-2004 11:30 |
How to change language to c28 v61 | iko | x1x to x45/x50 | 2 | 07-01-2003 18:34 |
How to change language to C28v61!!! | starpho | x1x to x45/x50 | 5 | 08-10-2001 20:31 |
