03-03-2009, 12:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | huawei t161l unlock done module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090303-150552.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090303-150554.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090303-150600.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090303-150620.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 65 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to nadim electro For This Useful Post: |
03-03-2009, 17:04 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Huawei-T161L UNLOCK DONE WITH LG-KG195 CABLE. | sajidashraf | Infinity-Box | 5 | 06-24-2010 06:50 |
Huawei-T161L unlock done with infinity | imran_hasham007 | Infinity-Box | 2 | 05-05-2009 17:36 |
huawei t161l unlock done | nadim electro | Infinity-Box | 2 | 01-28-2009 13:50 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
