s660 identification error problem unlocking s660 here logs COM2 [VCP1] selected Device: Aiko 17G Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6217:8A00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification, method #1... detection phase #1... . detection phase #2... ................ warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\MModule\id..__FFFFFFFF_.rpl warning: unknown identification structure: _FFFFFFFF error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update reading [eeprom]... Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: backup_eeprom_20070927-104856.B0E.bin flash: 98004900000001:29EA0000000000 Identification Fail Finished, time used: 29 sec Remove/Install battery now ! i have two phones both have same error never had a problem then in unlocking this phone only now |
Hello, Please, download latest MModule v1.61 from support area and try again. Also, as I can see, you did not selected correct model. According to your Log it was "Aiko-17G" model selected instead of S660, so pls select S660 and try again. |
can seem to find mmodule v1.61 from support same error if uwant i can send readout to you for an update COM2 [VCP1] selected Device: Philips S660 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6217:8A00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification, method #1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification information not found, possible reasons: .old firmware type w/o identification data .damaged firmware .damaged hardware detect device parameters finished warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\MModule\id..__FFFFFFFF_.rpl warning: unknown identification structure: _FFFFFFFF error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update reading [eeprom]... Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: backup_eeprom_20070928-104156.B0E.bin flash: 98004900000001:29EA0000000000 Identification Fail Finished, time used: 34 sec Remove/Install battery now ! |
Sorry, I don't understand. Is this log made with MModule v1.61 or you can't find MModule v1.61 in support area ? |
