Old 09-27-2007, 03:53   #1 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
s660 identification error
problem unlocking s660 here logs
COM2 [VCP1] selected
Device: Aiko 17G
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Connecting, wait...
Initializing[6217:8A00]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000001:29EA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
detect device identification, method #1...
detection phase #1...
detection phase #2...
warning: identification information not found, possible reasons:
.old firmware type w/o identification data
.damaged firmware
.damaged hardware
detect device parameters finished
warning: invalid identification, ask/rpl calculation reqired
error: rpl file not found: C:\Program Files\InfinityBox\MModule\id..__FFFFFFFF_.rpl
warning: unknown identification structure: _FFFFFFFF
error: ASK file can't be created, user action required:
1. download latest software from support area and try again !
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read detailed information" operation
- send "backup_system_log_..." file to support
- make "Read full flash" operation
- send flash backup file(s) to support
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
reading [eeprom]...
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
operation canceled by user
file saved: backup_eeprom_20070927-104856.B0E.bin
Identification Fail
Finished, time used: 29 sec
Remove/Install battery now !
i have two phones both have same error
never had a problem then in unlocking this phone only now
Old 09-27-2007, 14:00   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,485
Hello,
Please, download latest MModule v1.61 from support area and try again.
Also, as I can see, you did not selected correct model. According to your Log it was "Aiko-17G" model selected instead of S660, so pls select S660 and try again.
Old 09-28-2007, 03:52   #3 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
can seem to find mmodule v1.61 from support
same error if uwant i can send readout to you for an update
Device: Philips S660
Action: unlock
Boot...
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
.damaged firmware
.damaged hardware
reading [eeprom]...
file saved: backup_eeprom_20070928-104156.B0E.bin
Identification Fail
Finished, time used: 34 sec
Old 09-28-2007, 09:19   #4 (permalink)
Member: 130995
Sorry, I don't understand. Is this log made with MModule v1.61 or you can't find MModule v1.61 in support area ?
Dongle identification data damaged, error code #32 omega-telecom Infinity-Box 6 01-28-2009 08:47
Dongle Identification Data Damaged Error Codev #30???? ROUGHNECK Infinity-Box 1 05-23-2008 11:06
Dongle identification data damaged, error code #31 TALIAT Infinity-Box 1 05-03-2008 09:36
*****Dongle identification data damaged, error code #31**** HAROON's Infinity-Box 6 08-10-2007 15:25
Page generated in 0.23002 seconds with 8 queries
