Old 04-11-2015, 08:33   #1 (permalink)
Member: 1824929
Thanks Meter: 99
s7562 mt6572 dump writing problem
USBDL : Init HSUSB Ok!
ISPFF ID : 6572
TARGET ID : 6572
FlashFile is differs from eMMC settings, continue by user request
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
[ MCU ] : MT6572__ALPS__GT-S7562__ALPS.JB3.MP.V1.6__Android_4.0.4__20140217_0 60744.ispff
Init Ok , Sending blocks ...
Write failed
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:01:52
Reconnect Power/Cable!
Old 04-11-2015, 09:18   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
When you start post full logs - can say something.
Old 04-11-2015, 09:25   #3 (permalink)
Member: 1824929
Thanks Meter: 99
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A483447316404860CA2D24780A1
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A483447316404860CA2D24780A1
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : alps
ProdName : hexing72_wet_jb3
ProdModel : GT-S7562
Device : hexing72_wet_jb3
AndroidVer: 4.0.4
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1.6
Old 04-11-2015, 14:00   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Ok, better.
It stops randomly, or at same address/percent?
Old 04-11-2015, 14:15   #5 (permalink)
Member: 1824929
Thanks Meter: 99
yes same adress but dump not writing any solution
Old 04-11-2015, 14:22   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Write factory file, for example?
Old 04-11-2015, 14:30   #7 (permalink)
Member: 1824929
Thanks Meter: 99
Wait for phone...
Phone found! [ 5 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
Configure emi settings
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : hexing72_wet_jb3 , Storage : EMMC
Setting : AFF verify : Enabled
Switching to HSUSB
HSUSB Init Ok
SecCfg Passed , 1799
BL : Check HW compatibility
BL : Check eMMC compatibility
BMT remark not need. Will skip
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x00000000E5B00000
Erase Error! Something went wrong!
Done!
Elapsed: 00:00:19
when i untick flash erase phone flash sucessfuly but phone blue screen
Old 04-11-2015, 14:34   #8 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Looks like eMMC is dead. Or some other problem with CPU-eMMC connection or e.t.c.
Just to be sure about HW reason - try flash via SPFT with "download only" mode and check result. Let me know it.
Old 04-12-2015, 06:13   #9 (permalink)
Member: 1824929
Thanks Meter: 99
not write by sptool pmt error .. my phone dead via wrong flash by other tool there is no hw problem
Page generated in 0.23612 seconds with 8 queries
