Old 07-24-2005, 10:21   #1 (permalink)
bentys2000's Avatar
Member: 28334
Thanks Meter: 4
A10X new problem
i received 2 panasonics yesterday !!! when i power on its display 'panasonic ' i flash them always same thing what must'i do then ...
Old 07-24-2005, 11:55   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
It can be that you need to press and hold phone Power button for some time.
Also, some people reported that this problem can be solved by removing backup battery for some time (need to open phone, desolded backup battery and put it back).
Old 07-24-2005, 11:57   #3 (permalink)
Member: 97346
Thanks Meter: 14
sir,
try to key in *01763*737381# .....
if the code does not work use "reset settings" with your infinity-box
LS
Old 07-24-2005, 12:43   #4 (permalink)
bentys2000's Avatar
Member: 28334
Thanks Meter: 4
all done but always 'panasonic' onto display
Old 07-24-2005, 20:29   #5 (permalink)
Member: 22586
Thanks Meter: 36
I had a similar case with a X300.
I tried everything, but finally i discovered that some smart guy had rehotted the CPU. He thought that this would repair the freezing problem.
Sunday unlockers are always a problem.
Mike
Old 07-25-2005, 07:54   #6 (permalink)
balu_dark's Avatar
Member: 16251
Thanks Meter: 38
in more cases - just flash it with original flasher (FW,LP,MAP)
...::: New Problem With New Sharp Gx17 Blue :::... MATRIX.REAL Sharp 6 07-09-2008 16:26
New Problem with New K750I clinic*mobile Cruiser Suite 9 02-09-2007 19:33
New updates, new problems... byteforce Griffin 31 03-23-2006 18:32
New firmw. UFS3, new problem :( menintest UFS2 + UFS3-Tornadoflasher 6 08-25-2005 19:18
New Problem With New Motorolla V80 ahfid Motorola P2k 1 06-29-2005 19:53
Page generated in 0.18580 seconds with 9 queries
