Old 11-27-2008, 13:52   #1 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 775
Sagem My150X Unlock Failed
Dear Supporter,
I am tying to unlock Sagem My150x.
but after oparation its want Network subnet code and Default code is no OK
Here is LOG
COM8 [VCP0] selected
module v1.55
Device: Sagem-my150x
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
sw version: EAI_IC_300707_1408 300707_1408 EAI_IC Thhmm Dddmmmyyyy 01234567
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-sta...
file saved: C:\Documents and Settings\Administrator\Desktop\Sagem-my150x_eeprom-sta_20081127-183600.B1E.bin
loading data...
data loaded
reading eeprom-sec...
file saved: C:\Documents and Settings\Administrator\Desktop\Sagem-my150x_eeprom-sec_20081127-183604.B1E.bin
reading eeprom-complete...
file saved: C:\Documents and Settings\Administrator\Desktop\Sagem-my150x_eeprom-complete_20081127-183613.B1E.bin
reading additional data...
done
backup critical area Done
Check memory ...
current status: #1, already unlocked
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 77 sec
Remove/Install battery now !
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Old 11-27-2008, 14:58   #2 (permalink)
serkan45's Avatar
Member: 159363
Thanks Meter: 21
code 12345678 okkk
Old 11-27-2008, 16:31   #3 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 889
If stil same problem then u have to unblock ur phone other wise write new eeprom then all will be ok.
Old 11-27-2008, 16:58   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
@srkhan
Download latest Pana01 update from support area and try again.
Old 11-27-2008, 17:38   #5 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 775
Check memory ...
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 11-27-2008, 17:58   #6 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 775
and still Locked and asking for Subnet Code
Old 11-27-2008, 18:30   #7 (permalink)
Member: 130995
@srkhan
What module version you have used ?
What is the reason to ignore my advice ?
Old 11-27-2008, 18:41   #8 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 775
i will try tomorow with latest Pana module
Old 11-27-2008, 19:49   #9 (permalink)
Member: 130995
Hello,
Good answer...
Why tomorrow but not right after my first message several hours before ?
sagem my150x unlock mojtaba200 FuriousGold 3 05-07-2008 13:43
>>> sagem my150x unlocked successfull <<< keaelite Infinity-Box 1 05-06-2008 18:13
Sagem-my150x Unlock ok pardeeptelecom Infinity-Box 1 05-02-2008 15:07
sagem my150x unlock code johnridge Phone Unlocking Codes & Maps 0 03-22-2008 14:29
pls help on sagem my150x unlock in mt manekmobile07 ARM9 BASED M62 / M62+ 4 03-21-2008 15:13
Page generated in 0.30729 seconds with 8 queries
