04-28-2008, 14:39 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: pakistan Age: 43
Member: 705991 Status: Offline Thanks Meter: 115 | sagem my150x in unlock process dead |
04-28-2008, 17:41 | #6 (permalink) |
Member: 705991 Status: Offline Thanks Meter: 115 | sagem my150x sir what can we do we try to unlock that model if phone goes off i want to know that infinity had any solution because we r in trouble we need solution .before that model i have done it vodafone 226&sagem my 150x ok in this case i m in trouble the method was same but what wrongs it can'nt understand to me |
04-28-2008, 17:47 | #7 (permalink) | |
04-29-2008, 08:05 | #10 (permalink) |
Member: 705991 Status: Offline Thanks Meter: 115 | COM1 [Serial0] selected Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_030807_1302 030807_1302 EAI_IC Ag Bh ` Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sta_20080428-162921.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sec_20080428-162927.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-complete_20080428-162934.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area repair write error [002F6800]... Ok repair write error [002F7000]... Ok Write Done Finished, Remove/Install battery now ! Time used: 85 sec sir first of thanks here is the logs that phone who dead |
04-29-2008, 08:46 | #11 (permalink) |
Member: 705991 Status: Offline Thanks Meter: 115 | sir this another sagem my150x who unlocked ok thourgh infinity same procedure we apply here is the logs phone ok COM1 [Serial0] selected Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported sw version: EAI_IC_300707_1408 300707_1408 EAI_IC Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sta_20080429-123622.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-sec_20080429-123626.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my150x_eeprom-complete_20080429-123633.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 69 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-29-2008, 14:57 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, As I can see write error was recovered. Are you sure that phone was completely Ok before unlock ? Also, read flash from this phone and send to [email protected] (attach problem description in your mail) |
04-29-2008, 16:28 | #13 (permalink) |
Member: 705991 Status: Offline Thanks Meter: 115 | when i try to read eeprom its show me that error COM1 [Serial0] selected Device: Sagem-my150x Checking data, wait... Action: read flash Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... error: can't run preloader: middle part... error: can't run middle loader: boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Failed Finished, Remove/Install battery now ! Time used: 23 sec ihave eeprom back up can i mail u |
04-29-2008, 17:02 | #15 (permalink) | |
Error that I have seen in unlock log can't be a reason why phone can't boot. I suggest you to reball flash chip IC. | |
Sagem my150x successfully unlocked | zeerik | Infinity-Box | 1 | 12-04-2008 13:18 |
E101 dead in unlock process (repaired !!!) | mansito01 | PolarBox 3 | 10 | 04-26-2008 22:33 |
sagem my150x not unlocked | tenma | Infinity-Box | 1 | 04-13-2008 13:06 |
**First In Zamboanga Sagem MY150x Direct Unlock In Furious** | alfox | FuriousGold | 6 | 04-06-2008 04:17 |
**Sagem MY150x Direct Unlock In Furious** | Nonoyxp | FuriousGold | 1 | 04-03-2008 22:12 |
