09-22-2008, 06:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Maharagama, Srilanka
Member: 661090 Status: Offline Sonork: 100.1616818 Thanks Meter: 541 | sagem my150x unlock sucess Device: Sagem-my150x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... sw version: EAI_IC_251207_1558 251207_1558 EAI_IC Ag Bh ` Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-sta_20080922-102216.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-sec_20080922-102219.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my150x_eeprom-complete_20080922-102229.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 75 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to jatchaminda For This Useful Post: |
09-22-2008, 21:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
>>> sagem my150x unlocked successfull <<< | keaelite | Infinity-Box | 1 | 05-06-2008 17:13 |
Sagem-my150x Unlock ok | pardeeptelecom | Infinity-Box | 1 | 05-02-2008 14:07 |
My150X unlock sucess | sharaz191 | FuriousGold | 0 | 03-26-2008 10:25 |
sagem my150x unlock code | johnridge | Phone Unlocking Codes & Maps | 0 | 03-22-2008 13:29 |
pls help on sagem my150x unlock in mt | manekmobile07 | ARM9 BASED M62 / M62+ | 4 | 03-21-2008 14:13 |
