Old 11-07-2008, 14:50   #1 (permalink)
jepetu's Avatar
Member: 181633
Sagem My200x unlocked 100%
Here log, thanks Infinity Team!!!
COM4 [VCP0] selected
module v1.53
Device: Sagem-my220x
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0001:011A
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20081107-094433.B1E.bin
loading data...
data loaded
reading [eeprom-sec]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20081107-094436.B1E.bin
reading [eeprom-complete]...
file saved: C:\Archivos de programa\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20081107-094438.B1E.bin
reading additional data...
done
backup critical area Done
Check memory...
current status: 0
Check memory Done
Write...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, Remove/Install battery now !
Time used: 39 sec
Unlock instruction:
1. Power-On phone
2. Enter code: 12345678
The Following User Says Thank You to jepetu For This Useful Post:
Old 11-07-2008, 16:23   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 11-08-2008, 05:24   #3 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
good work mate
i already unlocked sagem 220v infinty is agreat box
sagem my200x pobleme???? adilosse SMTi 11 06-08-2008 13:34
unlock sagem my200x? zerocool2207 SwS_SaG_BoX 1 05-30-2008 14:56
Sagem My101x and My200X Unlok 100% using SWS-saG hitibiti SwS_SaG_BoX 2 07-23-2006 04:36
Sagem 9XX unlocker 100% by cable not manualy GSM Maniak Infineon C16X M51 & ARM7 M52 BASED 1 09-12-2000 03:14
Page generated in 0.21383 seconds with 11 queries
