Old 02-25-2010, 07:44   #1 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
alcatel not connect with software
got alcatel handset not conected with software. rx tx voltage ok . how two connect infinity team thanks
Old 02-25-2010, 11:11   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
Try to use test-points under battery.
You can see detailed information about Alcatel test points Rx/Tx/Gnd in Infinity-Box Shell.
Old 02-25-2010, 11:56   #3 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
thank u what is model no of this handset becos backsteker not there
Old 02-25-2010, 11:59   #4 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
there are no detail test point of alcatel
Old 02-25-2010, 15:40   #5 (permalink)
Member: 1043909
run Shell
select model "Alcatel C701" and you will see pinout + test point pictures
then select model "Alcatel S520" in software and make "read detailed information" and you will be able to check what is your phone model name.
Old 03-01-2010, 06:29   #6 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
thanks again bro 3 pic there last pic use positive supply direct to board
Old 03-02-2010, 07:30   #7 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
bro upload here test point pic plz
Old 03-02-2010, 08:06   #8 (permalink)
~AKSingh~'s Avatar
Member: 65063
Thanks Meter: 2,419
take help of this
br,
Old 03-02-2010, 10:46   #9 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
Smile
Originally Posted by ~AKSingh~ View Post
take help of this
br,
Ur Posted Pinout Is Working For These Models
Alcatel E100
Alcatel E100X
Alcatel E101
Alcatel E15x_16x_25x
Alcatel E201
Alcatel E205
Alcatel E207
Alcatel E221
Alcatel E227
Alcatel E230x
Alcatel E801
Alcatel S107
Alcatel V270
Your Model Is Like ALcatel S621x
Run Infinity Shell Select Brand Than Select Model
Than You Will See All Info
Regards.
UMER
Old 03-02-2010, 21:36   #10 (permalink)
Member: 1043909
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: http://www.infinity-box.com/news.php
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 03-02-2010, 22:48   #11 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1652282
Thanks Meter: 242
listen listen
if u have spider man .. connect it with spider man then set comport in infinity then unlock it
Old 03-02-2010, 22:51   #12 (permalink)
.:Mahmoud El-masy:.'s Avatar
Member: 459407
Sonork: 100.110689
Thanks Meter: 164
Originally Posted by GSM-XPERTS View Post
listen listen
it's best solution if you have spider or pinfinder
Old 03-03-2010, 00:13   #13 (permalink)
The_Dj's Avatar
Member: 178790
Sonork: 100.1593063
Thanks Meter: 1,234
broo...this is ALcatel V770
this pinout is very easy.
is same to C701
if not work change position to rx and Tx
Old 03-22-2010, 16:25   #14 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 56
no luck may be phone cpu damage thanks for support
6300 not connecting with software raza786 Infinity-Box 7 11-09-2008 22:11
Ztc t58 not connecting with software ..::Sunil::.. Infinity-Box 13 01-10-2008 23:25
k310i not connected with software irfaN_vu Cruiser Suite 0 10-25-2007 10:11
T720 dead. not connect with software NetSpider Motorola P2k 8 05-01-2006 19:11
v3 not connecting with software pakstar Motorola P2k 1 04-15-2006 21:19
Page generated in 0.21747 seconds with 11 queries
