04-12-2008, 08:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Russia norten-caucasus Age: 52
Member: 18234 Status: Offline Thanks Meter: 97 | sagem my220v good unlock i am tested COM1 [Serial0] selected Device: Sagem-my220v Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-114112.B1E.bin loading data... wrong database file: G:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-114115.B1E.bin reading [eeprom-complete]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-114120.B1E.bin backup critical area Done Check memory... completed Finished, Remove/Install battery now ! Time used: 29 sec COM1 [Serial0] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IH_290607_1125 290607_1125 EBI_IH Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-114235.B1E.bin loading data... wrong database file: G:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-114240.B1E.bin reading [eeprom-complete]... file saved: G:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-114246.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 80 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-12-2008, 09:03 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | For me NO my220v code erroné I have unlocked one but code erroné here is log: COM2 [VCP0] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IH_280607_2044 EBI_IH 280607_2044 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-103325.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-103329.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-103332.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 28 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-12-2008, 16:48 | #7 (permalink) |
Freak Poster Join Date: Apr 2003 Location: T.O
Member: 26447 Status: Offline Thanks Meter: 6 | my220X unlocked OK COM3 [Serial2] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-164238.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-164241.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-164251.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 52 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-12-2008, 19:30 | #8 (permalink) |
No Life Poster Join Date: Mar 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 55
Member: 60178 Status: Offline Thanks Meter: 30 | also me i put 123456789 look at this COM6 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080412-174106.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z225_eep65535.cfg error: can't load database v.13 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080412-174110.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080412-174117.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 45 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-15-2008, 19:00 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @..::Thanh_gsm::.. It's hard to use search option, it's for experienced professional people only @J_M @msantar run Infinity-Box Shell, select required model and see pinout. |
04-17-2008, 14:37 | #13 (permalink) |
Freak Poster Join Date: Apr 2006 Location: moldova Age: 48
Member: 259209 Status: Offline Thanks Meter: 37 | cant unlock my220x here's eeprom and log COM5 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sta_20080417-163252.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sec_20080417-163318.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-complete_20080417-163324.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 67 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
04-17-2008, 14:42 | #14 (permalink) | |
Member: 259209 Status: Offline Thanks Meter: 37 | Quote:
well done after 10 tryes | |
sagem my220v unlock | dindou78 | SAGEM JTAG UNLOCKER | 18 | 03-07-2008 17:53 |
Alcatel c701 good work i am tested | nafanya | Infinity-Box | 4 | 01-30-2008 18:50 |
how to unlock sagem my220v | chris2007 | SMTi | 2 | 11-16-2007 22:28 |
