10-01-2008, 01:50 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | sagem my220v :( I had a prob. There was a cable problem when unlockin and after Erasem it started to Write and did not finish, just got to 75%. I restored: Eeprom_full eeprom-sec eeprom-sta the phone is still dead I fI try to unlock again, when reading memory structure or something, it says that the firmware is not supported, that I should read it and send it to support, but I know this is becauase of tyhe writing error. How can I fix this ? I noticed there is no full flash for my220v on support area, only this file on repair section: Sagem-my220v_EBI_IO_141107_1557_lock_area_original.B1E.b in should I flash this? and what should I select it as? eeprom or firmware? |
10-02-2008, 23:47 | #4 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | OK, here is log for the 1st unlock operation which damaged the phine, remember it was a cable problem...: COM5 [VCP0] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH EBI_IH_170707_1253 Thhmm Dddmmmyyyy 0123456789ABCDEF DB Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20080930-180315.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20080930-180332.B1E.bin reading [eeprom-complete]... ] file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20080930-180344.B1E.bin reading additional data... done backup critical area Done Check memory... e current status: 0 Check memory Done Write... Erasing: lock-area error: erase failed: 00450000 Write Failed Finished, Remove/Install battery now ! Time used: 148 sec I restored all thjose files that were backed up, when tried to unlock again got this log: Current model: Sagem-my220v Ready COM5 [VCP2] selected Device: Sagem-my220v Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: EBI_IH EBI_IH_170707_1253 Thhmm Dddmmmyyyy 0123456789ABCDEF DB Check hardware Done Check parameters... Check parameters Done ] backup critical area... reading [eeprom-sta]... file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-sta_20080930-183310.B1E.bin loading data... data loaded e reading [eeprom-sec]... file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-sec_20080930-183320.B1E.bin reading [eeprom-complete]... file saved: C:\mobilestuff\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20080930-183322.B1E.bin reading additional data... done backup critical area Done Check memory... error: unknown firmware, read flash and send to support ! Check memory Failed Finished, Remove/Install battery now ! Time used: 107 sec |
10-03-2008, 08:14 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Flash phone with this file from support area (download from "mirror-1" or "mirror-2"): \flashfiles\Sagem\repair\Sagem-my220v_EBI_IH_170707_1253_lock_area_original.B1E.b in Waiting for your results. |
10-03-2008, 15:38 | #6 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | I want to try this but first tell me: should I use it as if it was eeprom file or as if it was a firmware file, I think this is important. |
10-03-2008, 16:01 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Load it as a eeprom. In fact it's not so important how to load this file due to almost all files in support area has not only data, but also address range inside flash file, so data will be flashed by correct address even if loaded like another part. |
10-04-2008, 23:49 | #8 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Data, Addresses, and compression/encryption also. Well, On-topic: It worked, the phone is repaired now, after successfully writing the file you posted on support I unlocked the phone and everything is allright. I dont what would be of infinitybox owners without your brilliant support, thank you, once again.,.. you deserve the money we all have paid for your box... |
how to unlock sagem my220v | chris2007 | SMTi | 2 | 11-16-2007 22:28 |
sagem my220v swisscom locked,pls help | jasimbinrashid | Phone Unlocking Codes & Maps | 0 | 09-25-2007 09:37 |
Had same prob, did this: | PeterK | Old Ericsson Phones & Sony Phones | 0 | 12-21-2000 23:48 |
