08-06-2008, 14:29 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: EGYPT Age: 42
Member: 11571 Status: Offline Thanks Meter: 24 | sagem my220x COM216 [VCP3] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080806-160559.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080806-160603.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080806-160610.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 85 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
08-06-2008, 15:10 | #4 (permalink) |
Member: 11571 Status: Offline Thanks Meter: 24 | COM216 [VCP3] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080806-165459.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080806-165502.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080806-165508.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 88 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 num 4 /5 & 6 is work ok now may be the 1st one is differant caze it's from orange network but another phones from etisalat egypt ??? |
08-06-2008, 21:17 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Ghana Age: 40
Member: 563167 Status: Offline Thanks Meter: 39 | infinity u are de best..........COM6 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sta_20080806-081237.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-sec_20080806-081244.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20080806-081255.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 219 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
09-05-2008, 07:40 | #8 (permalink) | |
Junior Member Join Date: Mar 2008
Member: 730976 Status: Offline Thanks Meter: 17 | Quote:
09-05-2008, 07:50 | #9 (permalink) |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | open infinity box shell select brand and then model there you will see cable name + pinouts by the way here is it Cable name: Bird-D736 keyboard top: Bird keyboard down: Sagem 1..........16 1: Gnd 9: Box Rx/Phone Tx (RJ45 pin 3) 10: Box Tx/Phone Rx (RJ45 pin 2) 16: Gnd Similar cables: Bird D615 Bird D736 Bird V708 Bird V750 Bleu 351x Bleu 411x Bleu 555x Bleu 651Z Bleu 700x Sagem my150x Sagem my200c Sagem my220v Sagem my220x Sagem my300c Sagem my411v Sagem my700X Vodafone 126 Vodafone 226 Vodafone 226FM Vodafone 527 Yes-Optus D736 |
09-05-2008, 12:52 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
help sagem my220x user code | Chawkiz_gsm | ARM9 BASED M62 / M62+ | 8 | 02-11-2011 08:26 |
23/09/08 : ET-BoX v1.73 Released - Sagem my220X + Boot Recovery for Vodaphone & Sagem | nonu_don | ET-BoX | 24 | 09-28-2008 07:41 |
23/09/08 : ET-BoX v1.73 Released - Sagem my220X + Boot Recovery for Vodafone & Sagem | nonu_don | Service Products News & Updates | 0 | 09-26-2008 11:24 |
SAGEM my220X unlock code? | nikkk | Phone Unlocking Codes & Maps | 2 | 12-29-2007 19:25 |
Sagem My220x | Tinotenda | SAGEM JTAG UNLOCKER | 2 | 12-24-2007 07:10 |
