05-07-2008, 07:22 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: philippines
Member: 232766 Status: Offline Thanks Meter: 22 | SAGEM My220x unlock success with pan v1.45 COM8 [Serial2] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sta_20080507-142047.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sec_20080507-142054.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-complete_20080507-142102.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 172 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 good job!! Infinity Team!!! br dlanor0221 |
05-07-2008, 09:13 | #4 (permalink) |
No Life Poster Join Date: Jul 2007 Location: PK
Member: 539052 Status: Offline Sonork: 100.1585495 Thanks Meter: 119 | I HAVE MY220X ,I DO PROCEDURE SAME BUT NOT UNLOCK COM29 [VCP0] selected Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sta_20080507-130441.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-sec_20080507-130449.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Sagem-my220x_eeprom-complete_20080507-130456.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 51 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
05-07-2008, 13:05 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | what problem are you facing ? is mobile say code error some thing like this then you have to wait 62 min with mobile on and then enter code you will unlock you mobile Br Faisal_Computer |
sagem my220x unlock successfully | bilal_mobile | Infinity-Box | 1 | 03-25-2009 13:54 |
sagem my220x unlockes successfully in 113 sec. | joni_rajpura | Infinity-Box | 3 | 02-19-2009 07:58 |
sagem my220x unlock successful | guljee786 | Infinity-Box | 4 | 02-10-2009 15:03 |
Sagem My220x Unlocked Successfully | mamepap | PolarBox 3 | 3 | 05-27-2008 02:41 |
