05-05-2009, 06:13 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 574441 Status: Offline Thanks Meter: 28 | Sagem my220x unlocked module v1.58 Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20090505-131136.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20090505-131138.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20090505-131143.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20090505-131210.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 90 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to mak_14344 For This Useful Post: |
05-05-2009, 21:14 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
SAGEM My220x unlock success with pan v1.45 | dlanor0221 | Infinity-Box | 8 | 05-20-2008 14:36 |
sagem my220x unlocking | Shakeel Communication | SMTi | 1 | 02-20-2008 15:41 |
SAGEM my220X unlock code? | nikkk | Phone Unlocking Codes & Maps | 2 | 12-29-2007 19:25 |
