01-01-2009, 17:28 | #1 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: ALGERIA
Member: 229016 Status: Offline Sonork: 100.1590620 Thanks Meter: 130 | Sagem-my225x unlock ok will down fast and easy Quote:
01-02-2009, 13:16 | #3 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Tunisia
Member: 188803 Status: Offline Thanks Meter: 4 | but for me here is the log COM3 [VCP0] selected module v1.59 Device: Sagem-my225x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 ECI_IN_300708_1004 ECI_IN 300708_1004 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-static_20090102-130948.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-security_20090102-130948.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-complete_20090102-130949.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_lock-area_20090102-130955.B1E.bin backup critical area Done Check memory ... error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 26 sec Remove/Install battery now ! |
01-02-2009, 14:50 | #5 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
u can ask any reseller | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
01-02-2009, 23:12 | #7 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
01-02-2009, 23:13 | #8 (permalink) | |
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
Are you sure that you have selected correct model ? | |
01-12-2009, 11:45 | #9 (permalink) |
No Life Poster Join Date: Nov 2006 Age: 41
Member: 389660 Status: Offline Thanks Meter: 60 | unlock ok COM4 [VCP1] selected module v1.60 Périphérique: Sagem-my225x Contrôle des données, attendre ... Operation: déverrouiller unlock method-1 Boot ... Appuyez et restez appuiez sur le bouton "Power" dès maintenant! loading... middle part... next part... boot answer: 01 lachez bouton d'alimentation maintenant! Boot Done Ensemble bauds ... 115200 Ensemble bauds Done Connecting ... Flash 0001:011A Connecting Done Check hardware ... sw version: 8 ECI_IN_300708_1004 ECI_IN 300708_1004 Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... lecture eeprom-static... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-static_20090112-114038.B1E.bin loading data... data loaded lecture eeprom-security... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-security_20090112-114039.B1E.bin lecture eeprom-complete... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_eeprom-complete_20090112-114043.B1E.bin reading additional data... fichier sauvegardé: C:\Program Files\InfinityBox\Pana01\Sagem-my225x_lock-area_20090112-114107.B1E.bin backup critical area Done Check memory ... lock found Check memory Done écrire ... Erasing: lock-area Writing: lock-area écrire Done Terminé, temps utilisé: 101 sec Retirez / remettre la batterie maintenant! |
The Following User Says Thank You to ahmed14 For This Useful Post: |
01-12-2009, 19:19 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
Sagem my225x unlock done | Akili Bulent | Infinity-Box | 22 | 12-03-2010 09:30 |
sagem my225x unlocking | UNIQUEM | ARM9 BASED M62 / M62+ | 17 | 06-24-2009 21:46 |
SAGEM My225x Unlocked with Pinfinity | topnoyze | Infinity-Box | 3 | 01-08-2009 20:58 |
Sagem my225x unlocked ok | GSMSERVE | Infinity-Box | 3 | 12-17-2008 14:05 |
