04-18-2009, 04:24 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Sagem my225x unlocked successfully my225x unlocked COM8 [VCP0] selected module v1.65 Device: Sagem-my225x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 ECI_IT_080808_1510 080808_1510 ECI_IT Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-static_20090417-202104.B1E.bin loading data... data loaded reading eeprom-security... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-security_20090417-202104.B1E.bin reading eeprom-complete... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-complete_20090417-202105.B1E.bin reading additional data... file saved: E:\InfinityBox\Pana01\Sagem-my225x_lock-area_20090417-202111.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 31 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to zeerik For This Useful Post: |
04-18-2009, 07:08 | #3 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | one more.............. COM8 [VCP0] selected module v1.65 Device: Sagem-my225x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820010 loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: 8 ECI_IT_080808_1510 080808_1510 ECI_IT Thhmm Dddmmmyyyy 0123 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-static_20090417-230709.B1E.bin loading data... data loaded reading eeprom-security... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-security_20090417-230710.B1E.bin reading eeprom-complete... file saved: E:\InfinityBox\Pana01\Sagem-my225x_eeprom-complete_20090417-230711.B1E.bin reading additional data... file saved: E:\InfinityBox\Pana01\Sagem-my225x_lock-area_20090417-230716.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 31 sec Remove/Install battery now ! |
The Following User Says Thank You to zeerik For This Useful Post: |
Sagem my225x unlock done | Akili Bulent | Infinity-Box | 22 | 12-03-2010 09:30 |
sagem my225x unlocking | UNIQUEM | ARM9 BASED M62 / M62+ | 17 | 06-24-2009 21:46 |
Sagem-my225x unlock ok | ponix | Infinity-Box | 9 | 01-12-2009 19:19 |
SAGEM My225x Unlocked with Pinfinity | topnoyze | Infinity-Box | 3 | 01-08-2009 20:58 |
Sagem my225x unlocked ok | GSMSERVE | Infinity-Box | 3 | 12-17-2008 14:05 |
