sam cdma s-399 successfuly unlocked COM6 [VCP0] selected module v1.02 Device: Samsung-SCH-S339 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 32 sec Remove/Install battery now ! here r logs thanx infinity team for support. do not be late plz add more models for cdma. |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. |
hi sir which cable to use i am using d800 rj45 cable of ufs it shows following error COM5 [VCP6] selected module v1.03 Device: Samsung-SCH-S339 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 22 sec Remove/Install battery now ! manually activated the testmode but no result also try the no 3 option but there is no keypad in the phone to try that option |
Hello, UFS cables is not compatible with Infinity-Box. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: http://www.infinity-box.com/download...shell_v126.jpg Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
sam s-339 pin out 1 Attachment(s) here is pinout dear.any problem pm me.i will give u solution |
which model u have select for unlocking of s399.???????????? because s399 not in list ??????????????????????????????????????????? Quote:
hi Quote:
hi connector type 12pin(l12c) infinity |
[B]phone is still locked [/B] COM8 selected module v1.03 Device: Samsung-SCH-S339 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 13 sec Remove/Install battery now ! |
done my too with com cable COM2 [VCP0] selected module v1.06 Device: Samsung-SCH-S339 Checking data, wait... Action: unlock Phone should be Switched ON ! Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 14 sec Remove/Install battery now ! |
good work infinity team working with reliance sim |
