Old 05-04-2009, 10:47   #1 (permalink)
Member: 358277
Thanks Meter: 475
sam cdma s-399 successfuly unlocked
COM6 [VCP0] selected
module v1.02
Device: Samsung-SCH-S339
Checking data, wait...
Action: unlock
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 32 sec
Remove/Install battery now !
here r logs thanx infinity team for support. do not be late plz add more models for cdma.
The Following 4 Users Say Thank You to jai2008 For This Useful Post:
Old 05-05-2009, 21:04   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
module v1.02
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-20-2009, 12:54   #3 (permalink)
Member: 353605
Thanks Meter: 6
hi
sir which cable to use
i am using d800 rj45 cable of ufs it shows following error
COM5 [VCP6] selected
module v1.03
Action: unlock
Connecting, wait...
error: can't activate test mode
If phone can not be connected after several tries make this:
1. Insert original sim card in phone
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456
4. go to "Port Map", HKF
5. select "UART1"
error: operation failed
Finished, time used: 22 sec
manually activated the testmode but no result
also try the no 3 option but there is no keypad in the phone to try that option
The Following User Says Thank You to safecell For This Useful Post:
Old 05-20-2009, 17:05   #4 (permalink)
Member: 130995
Hello,
UFS cables is not compatible with Infinity-Box.
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
F.A.Q., Contacts, Supported models, Cables/pinouts
Old 05-21-2009, 07:11   #5 (permalink)
Member: 358277
Thanks Meter: 475
sam s-339 pin out
here is pinout dear.any problem pm me.i will give u solution
The Following 2 Users Say Thank You to jai2008 For This Useful Post:
Old 05-21-2009, 08:11   #6 (permalink)
rajesh_ch's Avatar
Member: 618404
Sonork: 100.1624568
Thanks Meter: 287
which model u have select for unlocking of s399.????????????
because s399 not in list ???????????????????????????????????????????
module v1.02
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
The Following User Says Thank You to rajesh_ch For This Useful Post:
Old 05-21-2009, 08:38   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,138
no need to select model just press spunlock with any model selected
The Following 2 Users Say Thank You to deepakgarg For This Useful Post:
Old 05-21-2009, 10:04   #8 (permalink)
Member: 353605
Thanks Meter: 6
hi
i need s339 pinout not the s399
Old 05-21-2009, 12:50   #9 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,138
just post connector type or image of pcb.i ll give u pinouts
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 06-02-2009, 17:48   #10 (permalink)
Member: 353605
Thanks Meter: 6
hi
connector type 12pin(l12c) infinity
Old 06-03-2009, 16:37   #11 (permalink)
luqmaan751's Avatar
Member: 416940
Thanks Meter: 173
[B]phone is still locked [/B]
COM8 selected
module v1.03
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 13 sec
The Following User Says Thank You to luqmaan751 For This Useful Post:
Old 06-03-2009, 18:51   #12 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,138
COM8 selected
module v1.03
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
make rebuild efs and than spunlock
Old 07-12-2009, 14:57   #13 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 55
module v1.02
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
hi bro u use com cable or usb ? thanks
The Following User Says Thank You to vipinverma For This Useful Post:
Old 07-12-2009, 15:10   #14 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 55
done my too with com cable COM2 [VCP0] selected
module v1.06
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 14 sec
The Following 2 Users Say Thank You to vipinverma For This Useful Post:
Old 07-12-2009, 15:12   #15 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 55
good work infinity team working with reliance sim
W302 successfuly unlock with 1.07 unlocker HAMMZA_MOBILES Seking Server 3 07-27-2009 16:28
Post here successfuly unlocked fone with BB5Plus No TP Unlocker v2.00 by Zulea murtaza_nns Nokia Base Band 5 ( BB-5 ) 1 04-06-2009 17:51
c975 6.3.6 version successfuly unlocked without t p gsmservices Smart-Clip 0 12-28-2006 16:53
i want sam cdma n500(tata indicom) unlock code rathore_telecom Various CDMA/TDMA Cell Phones 6 01-10-2006 22:44
Page generated in 0.49665 seconds with 9 queries
