Old 09-23-2007, 04:18   #1 (permalink)
Member: 50304
Thanks Meter: 13
sams c140 problem
Dear frnds,
I got one samsung c140 for unlocking
i proceed as per documentation but the optiflash stops at "power on phone"
during flashing the infinity c140 special file from suppport area.
I selected right comport, right cable schematics rx tx, gnd and changed the various baud rates also. I am using slim plus box
What could be the problem. Pl.help.
Old 09-23-2007, 08:09   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Hi,
If phone cant be detected It can't be other problem, only cable problem or wrong COM port selected. Please, double check cable.
Old 09-23-2007, 17:20   #3 (permalink)
Member: 50304
Thanks Meter: 13
Thanx for the promt reply
I once again checked the com port and cable every thing ok. when I pressed the power on button as asked by optiflash, the phone gets powered on and it has not been detected at all.
Is there any TP or something
Pl.help
thanx again
Old 09-23-2007, 18:07   #4 (permalink)
Member: 130995
Hi,
It's no need to use any TP. Only ordinary Rx/Tx/Gnd cable (points under battery).
What cable you have used ?
Old 09-24-2007, 18:37   #5 (permalink)
Member: 50304
Thanks Meter: 13
I used pin out according to the pictures rx tx and gnd correctly. I interchanged rx and tx also for checking but no result.
nothing wrong in rj45 cable.pinouts and comport settings and the phone is brand new.
thanx
Old 09-24-2007, 18:59   #6 (permalink)
Member: 148515
Thanks Meter: 14,733
hello!
correct pinout is available in our shell.exe program. did you make cable according this picture?
each phone pin is marked with text where you can see to which box pin it must go
Old 09-25-2007, 02:49   #7 (permalink)
Member: 50304
Thanks Meter: 13
yes sir, I followed the exact picture
rj45 pin 3 to pin 2 of phone form top
2 to 3
7,8 to 5 (gnd)
The same rj45 cable i used for chinese phone works perfect.
thnx
Old 09-25-2007, 03:16   #8 (permalink)
Member: 572549
Thanks Meter: 172
sir just use ustpro2 no need to flash your C140 its direct unlock with ustpro2...........
Old 09-25-2007, 20:36   #9 (permalink)
Member: 148515
hello!
well, you can try to make this by other programs, but i dont think this will help.
Are you sure you setting right com port in flasher? you must set there com port which hold infinity box.
you can see its number via Device manager
Sam C140 Flashing Problem az cells Infinity-Box 2 10-21-2007 17:05
techgsm.com - New Nokia cable, Moto F3 cable, Sam C140 Cable and more... techgsm Main Sales Section 0 04-17-2007 22:17
Sam C140 unlock ??? sepia Samsung Flashers, Software, Firmware. 5 03-26-2007 23:59
Page generated in 0.48334 seconds with 8 queries
