07-17-2014, 08:37 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pAK+Africa
Member: 1190193 Status: Offline Sonork: 1619687 Thanks Meter: 406 | Samsun-e1282t-user code don Operation : Read User Code [ v0.07 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 376 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Check data... Can take some time User Code : 26269 Done! Elapsed: 00:01:15 Reconnect Power/Cable! |
The Following User Says Thank You to akhtar.abbas For This Useful Post: |
