06-07-2008, 16:05 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 449069 Status: Offline Thanks Meter: 61 | Samsun V55 Help Required! i am Having Samsun V55, which is Showing Booting Screen, Goes from 1% to 100% But Handset doesn't Switches On. I am Unable to format that Handset: ---------------------------------------------- Action: reset settings Model: Autodetect 6228 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 Connecting, wait... warning: wrong packet cs warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 128 sec Remove/Install battery now ! ----------------------------------------------------------------- Even Flashing Doesn't Help. ------------------------------------------------------- Device: Autodetect 6228 NAND Loading file v.02... K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04__V55-TV_64m_En_Cn.B4M.bin loaded identification#1 protocol ver: 04 ver. sw1: K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN ver. sw2: BC08v01.01b04, 4CB4305E You have loaded file with security features enabled. detecting languages... Languages: En Cn COM5 [VCP0] selected Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw1: K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN ver. sw2: BC08v01.01b04, 4CB4305E ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6228:8A02:8A02]... CPU: MT6228 high speed boot enabled chip: 0031:0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.0207 loader: 3.748.0 NAND id: EC76A5BD page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:007600A500BD [04200000] NOR chip is not installed Initialize Done Set baud... 460800 Set baud Done Identification... reading structure area... detecting structure... source data: page+spare converting data... done 0x00010000 bytes identification#1 protocol ver: 04 ver. sw1: K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN ver. sw2: BC08v01.01b04, 4CB4305E ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN_A1CF4BB 3].rpl identification#1 detection finished security area#1 calculation... Identification Done Write... file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN_A1CF 4BB3_20080607-134350.B4X.bin write core area 1 of 2... write core area 2 of 2... Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_27EADF DB_K2_PCB04_GPRS_MT6228_S02.BC08V01_01B04.BIN_A1CF 4BB3_20080607-135208.B4X.bin Finished, time used: 535 sec Remove/Install battery now ! ------------------------------------ How to Recover This Set Thanks |
06-08-2008, 15:52 | #3 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | Hi, Thanks a lot sir 4 ur reply. Yes the file used matches exactly. I Received the set in the above said condition. I Have read it's backup & then only i tried to format that set, which i was unable to do The i tried to flash the set with the file from support area, but the result is the same, Set at start up displays 1% then prompt continues upto 100% but then the screen becomes off, set doesn't switches on........... Please guide me how to recover this above set. Thanks |
06-13-2008, 16:07 | #5 (permalink) |
Member: 449069 Status: Offline Thanks Meter: 61 | Thanks a lot sir for ur reply. The Problem is definately with the Software, becoz the set is in this when the person is trying to take a photo & in between the set has switched off due to low battery. The Hardware inside is 100% Good. I also observe that there is no option for writing Eeprom/FFS for 6228 Processor, Will this option be helpful in such condition??? Thanks. |
Samsuns A767 help | wirelesshelpers | UST Pro II | 3 | 06-28-2009 10:35 |
need samsun e950 help | donnie1992 | Samsung Flashers, Software, Firmware. | 2 | 08-16-2008 11:07 |
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) | pazza198 | CAR Electronics | 3 | 04-06-2007 20:06 |
Can Anyone At All Help, ***MODERATORS AND CODE BREAKERS***** HELP REQUIRED (MEGANE) | pazza198 | CAR Electronics | 0 | 03-14-2007 17:48 |
PLZ.. HELP.. Desperate help required!! | /\/aB$ | Nokia Multimedia | 1 | 02-27-2004 05:45 |
