03-27-2011, 16:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1248435 Status: Offline Thanks Meter: 28 | samsung B159 never be unlocked HARDWARE : SCNNZ317 COMPILE : May 28 2010 (17:51:49) REALEASE : Mar 29 2007 (20:00:00) SW Version : QSC6010 SCNNZ 3170 --------------------------------------------------------- Phonce code : 0000 Finished, time used: 4 sec COM2 [Serial1] selected module v1.49 Device: Samsung-SCH-B209, B309, B319, B619, B339FM operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 26 secSCNNZ317May 28 2010 SAMSUNG B159 DE-26 selected.. samsung b159 de-26... downloading mode... Wait reconnecting port... Patching in progress... patching done... Wait reconnecting for restart... Done... Phones should be restart now... Finished, time used: 34 sec--------------------------------------------------------- i try to unlock with two steps but in second step never be succcesful Unlock samsung b119 new DC-26 version and B159 DE-26 version 1. If you want to unlock this phone , then must have Samsung E-210 cable of rj45 with usbport, because phone is unlocked in two steps that are following. 2. First of all phone should switch on and then after, connect the cable 3. Then select sacumdm in comport setting of infinity software 4. And now press unlock button and just wait for phone to Restart automatically 5. Then, after phone Restart you need to disconnect phone and use any Rj45 uni box or infinity box 6. And now select samsung Sch-B309 or b319 or b619 model from list and press spunlock button 7. If the sp unlock done by you get success then phone definitely be unlocked . If it is not success then , other step is as following we need to put this code 47*869#123580 in the phone, a menu will appear on the phone screen then select the option "portmap" then select hfk mode, after select hfk , select option of uart1 and save it . Then now, restart phone and try spunlock again by Step 2 NOTE- ITS VERY IMPORTANT , THAT ALL SP UNLOCK OPERATION MUST BE WITHOUT SIM, OTHERWISE THERE MAY BE LOSS OF ANY DATA OR MEMORY Hello, There is Force mode unlocking also why don't u try that put ur phone in boot mode press 9+PWR phone will B in boot mode now select rite samsung modem port them model and press force mode after done now perfrom Second step WBR <<<Megatron>>> Instruction to Unlock samsung b119 new DC-26 version and B159 DE-26 version 1)User must have Samsung E-210 cabel usb+rj45 ( 2 in 1 cable ) because phone is unlocked in 2 steps 2)USer should switch on phone and connect the cable 3)then select sacumdm IN COMPORT SETTING OF INFINITY software 4)Now press unlock and wait for phone to Restart 5)After phone Restart user need to disconnect phone and use any uni box or infinity box put rj-45 cable in box and connect phone using rj-45 6)Now select samsung Sch-B309,b319,b619 model from list and press spunlock 7)If sp unlock success then phone should be unlocked . If it is not success then User need to put this code 47*869#123580 , a menu will appear on the phone screen select the option "portmap" then select hfk after select hfk , select uart1 and save it . Restart phone and try spunlock again from Step 2 note VERY IMPORTANT :All sp unlock operation should be without sim |
03-27-2011, 16:43 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Just Imagine Age: 42
Member: 1191481 Status: Offline Sonork: 1592603 Thanks Meter: 1,373 | Quote:
Ur Phone Must B IN HFK Mode For Uart Unlock Check Ur Cable is It Ok Or Not Check Weather You Have selected Rite Port Try Other Cable And Check Wbr <<<Megatron>>> | |
03-29-2011, 18:14 | #3 (permalink) |
Member: 1248435 Status: Offline Thanks Meter: 28 | Hello, Ur Phone Must B IN HFK Mode For Uart Unlock Check Ur Cable is It Ok Or Not Check Weather You Have selected Rite Port Try Other Cable And Check Wbr <<<Megatron sir i check my cable it is 100% ok and i check all procedure that you have already written in other post i try this model by all procedure but always failed sir do somthing for that model thanks |
03-29-2011, 18:26 | #4 (permalink) | |
We Have Nothing To Do Now Ball Is In Ur Hand's It's Depends How U Through Did U Check Another Samsung Phone Which Share Same Cable Is It Connecting Did U Try To Rebuild UR Phone Then Perfrom Unlock Operation Wbr <<<Megatron>>> | |
03-29-2011, 18:55 | #5 (permalink) |
Freak Poster Join Date: Dec 2003 Location: CELLCARE
Member: 47627 Status: Offline Sonork: 100.1596335 Thanks Meter: 124 | Most important thing to unlock B159 is to use perfect drivers , if u have any kind of HSP driver installed before just uninstall all old drivers ,install new from support area i did face this kind of problem when i tried to unlock . Just check with your drivers all will be fine . regards nikhil_gsm |
03-30-2011, 19:22 | #7 (permalink) | |
When You Are Using UART Cable Then No Need Of Driver's Check Ur Phone Jack Etc Or Try To Put Ur Phone In HFK Mode Wbr <<<Megatron>>> | |
03-31-2011, 18:31 | #8 (permalink) |
Member: 1248435 Status: Offline Thanks Meter: 28 | sir my phones jeck is 100% ok because it is a new phone i tried by all methods but in 2nd method it cannot be unlocked sir is there somthing wrong in my phone version because it shows main de28 and all methods are for de26 |
03-31-2011, 18:50 | #9 (permalink) | |
Nothing Wrong Dear DE28 Is Supported Ok If U Have Dll Then Rebuild Phone Through Samsung Pst Using Usb Cable Phone Must B fully Powered On After Rebuild Unlock Via Uart Cable No Need Of step 1 As You Have Already Done It Try And Post Result Wbr <<<Megatron>>> | |
04-03-2011, 17:25 | #10 (permalink) |
Member: 1248435 Status: Offline Thanks Meter: 28 | Hello, Nothing Wrong Dear DE28 Is Supported Ok If U Have Dll Then Rebuild Phone Through Samsung Pst Using Usb Cable Phone Must B fully Powered On After Rebuild Unlock Via Uart Cable No Need Of step 1 As You Have Already Done It Try And Post Result Wbr <<<Megatron>>> sir i tried on web but there is no availabilty on net please give us Dll and pst tool for rebuiled |
04-03-2011, 17:50 | #11 (permalink) | |
You Can Use Any Dll Example B119 Mts Also Works Wbr <<<Megatron>>> | |
04-08-2011, 06:38 | #13 (permalink) | |
Please Use Seardc Button Here GSM-Forum - Search Forums Wbr <<<Megatron>>> | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
