samsung b159 unlock PROBLEM allredy 1st use usb done ffhone restart after code 47*869#123580 , a menu will appear on the phone screen select the option "portmap" then select hfk after select hfk , select uart1 and save it . Restart phone and try spunlock again from Step 2 already do this after phone display shwo ENTER COMMAND INPUT VELUE INDEX*01 COM2 [VCP0] selected module v1.41 Device: Samsung-SCH-B209, B309, B319, B619, B339FM operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 26 sec Report Post Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post! |
Change Cable And Then Perform Unlock Operation Again This Some Time Happens When Cable Is Not Proper Or If Not Works Then Power Off Ur Phone Connect With Cable Press Spunlock Now Power on Phone Hope It Will Solve The Problem Wbr <<<Megatron>>> |
