Old 11-26-2010, 02:43   #1 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Cool Samsung B239 unlocking problem.
COM59 [sscdmdm0] selected
module v1.38
Device: Samsung-SCH-B239, B259, B279, F302
operation: SP-unlock
Phone should be Switched ON !
connecting...
Connecting, wait...
error: can't activate test mode
If phone can not be connected after several tries make this:
1. Insert original sim card in phone
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456
4. go to "Port Map", HKF
5. select "UART1"
error: operation failed
Finished, time used: 20 sec
please help me. i have changed UART1 in HKF portmap but still showing the same result.
Old 11-26-2010, 03:09   #2 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 895
My friend rj45 cable and click on uart unlock
Old 11-26-2010, 03:10   #3 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Hi. i have only USB cable
Old 11-26-2010, 04:27   #4 (permalink)
<<<MEGATRON>>>'s Avatar
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,371
Hello,
For B239 you must use UART Back cable if. U didn't have UART cable then U can find Pinouts in Shell
WBR
<<<Megatron>>>
The Following User Says Thank You to <<<MEGATRON>>> For This Useful Post:
Old 11-26-2010, 14:41   #5 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Cool sir i tried UART cable but getting same response
COM62 [VCP0] selected
module v1.38
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
Finished, time used: 26 sec
please help me...
Old 11-26-2010, 14:51   #6 (permalink)
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,371
please help me...
Hello,
Check Ur Cable Connectivity First ? If Ok Then Check Port? If Ok Then try To Rebuild Ur Phone After Rebuild Perform Unlock Operation If All Not Work Then Follow These Steps Carefully
2. Power-On phone
3. go to Menu, press 6 then * and type password 123456 Or 123580
5. select "UART1"
After This Perform Unlock Operation
Wbr
<<<Megatron>>>
Old 11-26-2010, 14:53   #7 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Cool
Originally Posted by <<<MEGATRON>>> View Post
Hello,
2. Power-On phone
5. select "UART1"
Wbr
<<<Megatron>>>
i've done all these. i'm doing in jaf box. i selected jaf port. is it correct?
Old 11-26-2010, 14:57   #8 (permalink)
Member: 1191481
Sonork: 1592603
Thanks Meter: 1,371
Hello,
If You Are Doing Via Jaf U Must Emulate Com Port First Then Perform Unlock Operation
Connect Me On Yahoo- megatronjo
Wbr
<<<Megatron>>>
Old 02-02-2011, 12:26   #9 (permalink)
Member: 946927
Thanks Meter: 6
i ve no orgenal sim card what i do pls hep infinity teame urgent
Old 02-02-2011, 17:08   #10 (permalink)
Registered User
Member: 1420255
Thanks Meter: 59
Samsung B239 unlocking problem.solution .......... samsung b239 many handset not unlock with infinity cdma setup today i have ten new set try with infinity cdma but same problem i have try with usb and rj 45 cable with infinity box but same problem set not going in test mode.After i have only main infinity box in model select samsung b 239 with use rj 45 cable yet set is unlock .i think infinity cdma software in few handset unlocking problem . so please it problem use main infinity box shell.
Old 03-08-2011, 12:16   #11 (permalink)
Member: 1315046
Thanks Meter: 36
Hello,
2. Power-On phone
5. select "UART1"
Wbr
<<<Megatron>>>
Please help me sir i've same problem with samsung B259
Old 03-08-2011, 13:18   #12 (permalink)
Infinity-CDMA's Avatar
Member: 1319166
Thanks Meter: 1,476
What same problem where are logs ?
Hi ,
Post logs b259 use uart cable check hardware may be connector damage .For Better result please post what cable used what is condition of connector of the phone and logs .
wbr
Old 03-08-2011, 14:40   #13 (permalink)
Member: 1315046
Thanks Meter: 36
Originally Posted by Infinity-CDMA View Post
Hi ,
wbr
COM3 [VCP0] selected
module v1.43
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
i'm using cable of B139, by which i've Succesfully unlocked Samsung B279 -
module v1.46
connecting...
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 17 sec
Old 03-08-2011, 14:50   #14 (permalink)
Member: 1319166
Thanks Meter: 1,476
Now it is better you posted logs.
module v1.43
connecting...
Connecting, wait...
2. Power-On phone
5. select "UART1"
module v1.46
connecting...
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
HI ,
module v1.46
connecting...
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Can you see you used latest module for b239 but using old module for b259 use latest module not the old one .There was problem in module 1.43 but was fixed in new module please visit support and use latest module .Wating for logs of new module .
wbr
Old 03-08-2011, 14:59   #15 (permalink)
Member: 1315046
Thanks Meter: 36
HI ,
module v1.46
connecting...
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
wbr
Sorry sir it's all my mistake,
now
Succesffully unlocked -
module v1.46
connecting...
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 22 sec
Thanx a lot.
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 15:21
Page generated in 0.44183 seconds with 8 queries
