samsung b310e after flash no power on ======= Flash Files set for flashing : [ MCU ] : SPD6530_SAMSUNG_00800000_MOCOR_W13.09_FP_R5.0.2_De bug_sc6500_samsung_PitonDS_SWA_09242014104316_en__ samsung-b310e.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 ======= Flashing MCU Mapping file ... Mapping done Processing file : SPD6530_SAMSUNG_00800000_MOCOR_W13.09_FP_R5.0.2_De bug_sc6500_samsung_PitonDS_SWA_09242014104316_en__ samsung-b310e.bin Init ok, send data Flashing Done! Info : In some cases after flash required make "Format Fs / Reset Phone" Done! Elapsed: 00:01:55 Reconnect Power/Cable! Operation : Format File System [ v1.13 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 4 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Verify data... Can take some time Error while prepare! Please, send FlashDump + log to support! Reconnect Power/Cable! |
Hello, What as phone condition before flash? Try to repair FFS or flash with other firmware. Br. Infinity Box Support Team. |
