01-11-2010, 22:30 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 251865 Status: Offline Thanks Meter: 15 | samsung camcorder blocked. this is name of his full flash make with infinity box: T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN__ fullflash_20100111-150309.B0M.bin look pictures: |
01-12-2010, 17:38 | #3 (permalink) | |
Member: 251865 Status: Offline Thanks Meter: 15 | Quote:
yes end this is log: ==== log: [11/01/2010 15:09:16] ==== COM4 [VCP0] selected module v3.04 Action: reset settings ("format ffs") Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001E03:0001 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21warning: wrong packet cs 22 23 24 25 26 27 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 42 sec Remove/Install battery now ! | |
01-12-2010, 22:06 | #5 (permalink) |
Member: 251865 Status: Offline Thanks Meter: 15 | i have read the full flash without error. ==== log: [11/01/2010 14:54:49] ==== COM4 [VCP0] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001E03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.04, database date: 24.12.2009): T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN.B IN project-id: T08B_ML_V001_DL_CN, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN__ fullflash... file saved: C:\Program Files\InfinityBox\ChineseMiracle\samsung digital\T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001 _DL_CN__fullflash_20100111-150309.B0M.bin Finished, time used: 8 min 55 sec Remove/Install battery now ! Last edited by murien; 01-12-2010 at 22:15. |
01-14-2010, 17:57 | #10 (permalink) |
Member: 251865 Status: Offline Thanks Meter: 15 | this log of complete format: but the touch screen always blocked! log: [14/01/2010 17:34:44] ==== COM4 [VCP0] selected module v3.04 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") Do you want to make ffs/eeprom backup before format ? ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001E03:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.04, database date: 24.12.2009): T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN.B IN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 04 sw version: T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN.B IN project-id: T08B_ML_V001_DL_CN, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T08B_ML_PCB01_GPRS_MT6225_S00.T08B_ML_V001_DL_CN__ ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\T08B_ML_PCB01_GPR S_MT6225_S00.T08B_ML_V001_DL_CN__ffs_20100114-173715.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 Finalization Done Finished, time used: 2 min 29 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
01-14-2010, 22:59 | #12 (permalink) | |
this is the full flash: http://rapidshare.com/files/33435124...M.bin.zip.html | |
Samsung SCM105 MPEG4 Sports Camcorder w/10x Optical Zoom | IPMART | ipmart WebShop | 0 | 10-21-2008 12:20 |
Samsung DC164 DVD Camcorder with 33x Optical Zoom | IPMART | ipmart WebShop | 0 | 10-21-2008 12:20 |
Samsung SC-MX10 Flash Memory Camcorder with 34x Optical Zoom (Pink) | IPMART | ipmart WebShop | 0 | 10-21-2008 12:20 |
Camcorder for Samsung E715 | softsearching | Nokia Multimedia | 13 | 05-28-2005 00:00 |
Does the samsung p510 have sound on the camcorder? | carlyrules | SYSOL Platform | 0 | 12-29-2004 18:54 |
