12-28-2016, 08:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Searching....
Member: 1442705 Status: Offline Thanks Meter: 1,061 | Lava A67 hag on logo done by CM2 Chinese Miracle II [SPD module] v 1.24 Loading : LAVA_A67_S113_20160627.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : LAVA_A67_S113_20160627 FastCheck : 0x00618B98A2 Loading files ... e : nvitem_wcn.bin File : prodnv.img File : u-boot-spl-16k.bin File : SC7702_pike_ File : fdl1.bin File : fdl2.bin File : nvitem.bin Filmodem.bin File : DSP_DM_G2.bin File : SC8800G_pike_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : oem.img File : persist.img File : sysinfo.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : cache.img File : u-boot.bin File : SC7730_UMS.xml Load Ok! 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 24 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x1A records PMTManager : PMT Update Ok! Flashing now [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_pike_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_pike_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : OEM Current File : oem.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : PERSIST Current File : persist.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : SYSINFO Current File : sysinfo.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:01:52 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Absar_Global For This Useful Post: |
04-11-2018, 17:25 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
