samsung clone rtech72_we_72_kk need firmware please i need firmware for this phone rtech72_we_72_kk ( samsung clone ) problem : stuck on logo all work fine : recovery - and charging in recovery android system recovery 3e p500ha_v006 ************************************ Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014AECA61BB00B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014AECA61BB00B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0D434F4DF2A3E2A94CAB325D3AD9E495 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : rtech72_we_72_kk ProdModel : rtech72_we_72_kk Device : rtech72_we_72_kk AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 SECURITY : IMEI_SW [1] : 358628300xxxxxx IMEI_SW [2] : 358628300xxxxxx BTMAC Addr : D2EE46xxxxxx WiFi MAC : 000000000000 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n EXTRA : LCD [0] : otm1283a_hd720_dsi_vdo LCD [1] : JD9365_hd_dsi_vdo LCD [2] : nt35521_hd720_dsi_vdo_boe LCD [3] : R63350_hd720_dsi_vdo LCD [4] : ili9881_hd720_dsi_vdo LCD Res : 1280#800x720#480 TOUCH [0] : GT9157 TOUCH [1] : ft6x36 TOUCH [2] : GT9XX TOUCH [3] : GT9158 TOUCH [4] : GT970#GT9XX TOUCH [5] : GT9158 CAM [0] : gs5604mipi_yuv CAM [1] : gc0310mipi_yuv CAM [2] : bf3a20_mipi_yuv CAM [3] : gc2145mipi_yuv CAM [4] : s5k4ecgx_mipi_yuv CAM [5] : ov5645_pip_yuv CAM [6] : ov7695_mipi_yuv CAM [7] : sp1628_yuv CAM [8] : hi256main_mipi_yuv CAM [9] : hi256_mipi_yuv CAM [10] : gc2165mipi_yuv CAM [11] : gc2165main_mipi_yuv CAM [12] : ov2675main_mipi_yuv CAM [13] : ov2675mipi_yuv# CAM [14] : ov5645_pip_yuv CAM [15] : ov7695_yuv hi258_mipi_yuv hi704_yuv ov5645_mipi_yuv gc2035mipi_yuv gc0329_yuv s5k5eayx_yuv MODEM : P500_band_1_2_5_8_gps_co_clock LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB fa_IR hi_IN bn_IN Done! Elapsed: 00:00:12 Reconnect Power/Cable! ************************************************** * Operation : Fix Android Partitions [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014AECA61BB00B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014AECA61BB00B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0D434F4DF2A3E2A94CAB325D3AD9E495 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Refill : Cache Refill Ok! Refill : UserData Refill Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! ************************************************** **** Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014AECA61BB00B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014AECA61BB00B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0D434F4DF2A3E2A94CAB325D3AD9E495 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3772 mV [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BMZW5 , 0xE9000000 , 3728 MiB [eMMC] : CID : 1501004E35575A4D42014AECA61BB00B [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:35 Reconnect Power/Cable! ********************************************* please help |
problem solved think you ;) **************************************Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : rtech72_we_72_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : rtech72_we_72_kk Device CPU : MT6572 Device IntName : rtech72_we_72_kk Device Version : 4.4.2 Device Compile : 3/23/2017 7:03:14 AM Device Project : ALPS.KK1.MP6.V1 Device ExtInfo : rtech72_we_72_kk Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014AECA61BB00B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014AECA61BB00B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x0D434F4DF2A3E2A94CAB325D3AD9E495 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : rtech72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3795 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E5C80000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:39 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:53 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:50 Reconnect Power/Cable! ************************************************** ********** |
Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
