05-22-2014, 12:47 | #1 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Samsung E1200i read flash not work can you fix this ? Quote:
Battery is fully charged. I use china spd v0.05 that should support E1200i With E2202 not have this problem and read flash work correct. | |
05-22-2014, 12:59 | #3 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Hi thanks for answer will test in 1h and give know here. Now flashing E2202 dead that I got with fullflash readed from working phone. |
05-22-2014, 13:10 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | We had some test with E2202 - it work well with "cloned" flash. If phone not power on after flash with file from sure working phone, not want format - that mean FlashIC fault. |
05-22-2014, 13:12 | #5 (permalink) | ||
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
About E1200i: I select like you write and got this: Quote:
The Following User Says Thank You to wgmmmx1 For This Useful Post: |
05-22-2014, 13:18 | #6 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Yes, it work as I think Please, test also repair IMEI, because I had only 2 samples. Need just know - work it on rest models or not. For repair Samsung exactly - need select Samsung in CPU generation. Also, will be good have one E1200i dump |
05-22-2014, 14:18 | #7 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Here is dump from E1200i https://mega.co.nz/#!Ig8WTZgZ!XO2Lpu...6K2mAWUHt2LLE4 |
05-22-2014, 14:27 | #8 (permalink) | |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Imei change in E2202 working too correct I tested about 5 phones: Quote:
05-25-2014, 13:05 | #10 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I've managed to revise Samsung support. Now it require select correct model. Rest is same. Supported phones : GT-E1200i , GT-E1202i GT-E1270 , GT-E1272 GT-E1280 , GT-E1282T If I miss some - let me know. |
The Following User Says Thank You to Dzirt For This Useful Post: |
05-25-2014, 13:18 | #12 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Oh, I forget GT-E2202,GTE-2200 were supported already. GT-E1200Y , if it on SPD653x - will work as well. |
11-22-2014, 20:39 | #14 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | All files you got in infinity box support ftp just get file from there. |
