03-11-2009, 21:21 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
07-23-2009, 18:29 | #4 (permalink) | |
Freak Poster Join Date: Nov 2005
Member: 202820 Status: Offline Thanks Meter: 11 | Quote:
thanck i wainting | |
07-24-2009, 11:17 | #5 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. | |
Compatible Touch Pen for Samsung F488 Phone (silver) | IPMART | ipmart WebShop | 0 | 12-13-2008 07:25 |
please add flash files for samsung F488! | xiakaijun | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 12-11-2008 16:16 |
Compatible Silicone Case for Samsung F488 Phone (white) | IPMART | ipmart WebShop | 0 | 10-15-2008 10:20 |
Compatible Silicone Case for Samsung F488 Phone (black) | IPMART | ipmart WebShop | 0 | 10-15-2008 10:20 |
Compatible Touch Pen for Samsung F488 Phone | IPMART | ipmart WebShop | 0 | 10-10-2008 14:10 |
