05-21-2017, 07:37 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | samsung g530h imei write help i try this. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Done with Samsung Tool PRO v.28.1 i also try this, Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button Done with Samsung Tool PRO v.28.1 |
