10-25-2018, 08:06 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | redmi 6 mtk da and auth needed i have redmi6 MT6765 bricked any have da and auth file for this ps: i try auth flle on MiFlash20180528 folder didnt work Code: Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM49) MODE : BOOTROM PORT : 49 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+SEL BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled BROM : SLA BROM : Selected Auth/Cert not accepted by device! Check previous message for more info! Reconnect Power/Cable! Code: Operation : Identify [ v2.00 r4 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM49) MODE : BOOTROM PORT : 49 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6765 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E7 BROM : SecMode : SBC+SLA+SDA+SEL BROM : BOOTROM MODE : 0_base : BASE_v1816 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_PL.bin AGENT : Found MT6765 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00000001 : DA SEND ERROR! ERROR : SECURE BOOT : SLA NOT PASSED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! |
10-25-2018, 10:01 | #2 (permalink) |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Only da and auth will not work because it's need permission from xiaomi server like qualcomm based handset or need VIP DA (currently not have) if handset able to boot into recovery can flash ota file |
The Following User Says Thank You to kamal_singla For This Useful Post: |
