Old 03-15-2016, 11:53   #1 (permalink)
Member: 2203712
Sonork: 100.1667064
Thanks Meter: 82
Urgent help needed
tecno f7
phone condition was hanged on logo
after flashing firmware with sp flash tool, fone now dead
when i read info with my wonderful cm2, this is the error result that i get.
Solution is urgently needed...
chinese miracle ii [mtk module] v 1.43
operation : Check / read info [ v1.43 ]
1. Power off phone , remove battery , insert back
2. Insert usb cable. In some cases require hold bootkey
wait for phone...
Phone found! [ 12 ]
sync...
Inital boot ok!
Bb_cpu_pid : 6583
bb_cpu_nme : [mediatek] mt6583|6589_s00
bb_cpu_ext : 0xca01 , 0x8a00 , 0x0000
processing brom stage
settings for brom configured!
Seccfgval : 0x00000000
bromver : 0x0005
blversion : 0x00fe
preloader : Not active [ erased ]
bootldrss : Normal with spreloader
processing da stage
da select done, will use mtk_allinone_da_v5.1552.01.01
sending and initialize da ...
Running da ver.3.2 on bbid : 0x86
nand flash : Not installed
emmc flash : 204a0190594e49589ca116487790c02f
initialize memory ...
[da_error] : Dram configure failed!
Errocode : 0x2003
emicfg_not_found
try not hold volume(+/-) keys on connect!
Boot error!
Operation failed
elapsed: 00:00:50
reconnect power/cable!
Old 03-15-2016, 12:53   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
preloader erased
full flash with firmware/backup enough for back alive
post result/logs....
Old 03-15-2016, 12:55   #3 (permalink)
Member: 952475
Thanks Meter: 26
Flash Without press vol+ aur Vl-
Flash Without press vol+ aur Vol- also boot cable
Page generated in 0.18225 seconds with 9 queries
