04-02-2016, 16:22 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | SAMSUNG I9060 MT6572 IMEI repair problem I have flashed with many files but i am not able to (write security) invalid imei of this fone. Code: Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:35 Reconnect Power/Cable! Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 317 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A1F889E85019 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1F889E85019 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 37C15CCA15A12BC284764B83A8790B65 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : GT-I9060 ProdModel : GT-I9060 Device : y7260 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : JDQ39.I9060ZSUAND1 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_1_wg_n EXTRA : LCD [0] : yb_fl10801_dsi_vdo_lcm LCD [1] : yb_rm68171_dsi_vdo_lcm LCD [2] : LCD [3] : yb_nt35510_dsi_ylt_lcm LCD [4] : yb_rm68171_dsi_vdo_lcm LCD Res : 800x480 TOUCH [0] : ft5206 CAM [0] : s5k4ecgx_mipi_yuv CAM [1] : ov5645_mipi_yuv CAM [2] : t8ev5_mipi_yuv CAM [3] : hi704_yuv CAM [4] : gc0328_yuv CAM [5] : sp0838_yuv CAM [6] : gc2035_yuv MODEM : sanstar72_wet_jb3_hspa_gemini_7252 LOCALE : en_US es_ES ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT fa_IR hdpi sw320dp Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Repair Security [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 317 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Repair Security [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 317 ] Sync... Device boot not done Check Drivers Try again Init Service mode failed, something went wrong :( Reconnect Power/Cable! Operation : Repair Security [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 317 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A2058494E594816A1F889E85019 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , HYNIX [eMMC] : FLASH_CID : 90014A2058494E594816A1F889E85019 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 37C15CCA15A12BC284764B83A8790B65 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 354345343543543 Set IMEI [01] : 354346435453435 Prepare finished. Security check required! Wait for phone... Phone found! [ 317 ] Sync... Device boot not done Check Drivers Try again Error while post-checking procedure! Check drivers and battery charge! In some cases - need reconnect mobile (just re-insert cable) on this step Reconnect Power/Cable! |
