03-19-2016, 05:30 | #1 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2530239 Status: Offline Thanks Meter: 14 | Samsung i9060 not remove **** virus Chinese Miracle II [MTK module] v 1.43 Operation : Remove Viruses [SmartAV] [ v1.43 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D00B28C54374F0B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D00B28C54374F0B [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : F8827405FFD40A18F70DFA86DD633E4A INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 1 Removing infected files and scripts ... SmartAV Report : Removed 1 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! Done! Done! Elapsed: 00:00:58 Reconnect Power/Cable! Operation : Scan APPs [DDirect] [ v1.43 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D00B28C54374F0B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D00B28C54374F0B [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : F8827405FFD40A18F70DFA86DD633E4A INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DDirect : Init Ok! Scanning FileSystem now , please wait [User Select] : Remove Files and Garbage [DDCleaner Info] : Files to remove : 0 [DDCleaner Info] : Additional garbage detected : 0 Removing files ... [DDCleaner] : Removed 0 Special Op #1 : Clear Recovery Data Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:01:30 Reconnect Power/Cable! |
03-19-2016, 06:48 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, First use latest version 1.44. Use App manager, first read manual from support how to use it and remove malware/virus manually. Here is link for pdf- App Remove Br. Infinity Box Support Team. |
03-19-2016, 16:12 | #4 (permalink) |
Member: 2530239 Status: Offline Thanks Meter: 14 | help me pld daed after flash problem not working vul up boot Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D00B28C54374F0B Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! |
03-21-2016, 03:25 | #9 (permalink) |
Member: 2530239 Status: Offline Thanks Meter: 14 | help me pls error wite flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Flash [ v1.43 ] ======= Flash Files set for flashing : [ MCU ] : MT6572__SAMSUNG__GT-I9060I__ALPS.JB3.MP.V1__Android_4.4.4.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : A5A5 BB_CPU_HW : A5A5 BB_CPU_SW : 5678 BB_CPU_SB : 5678 BB_CPU_NM : [MediaTek] MTxxx BB_CPU_SN : 0876EE7F0E4C0E8BC0FCC9F4F90BAA4C BROM Protocol Version : 05 Setting... RTC/PowerLatch Settings Failed #1 (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
03-21-2016, 03:25 | #10 (permalink) |
03-22-2016, 10:53 | #12 (permalink) |
Member: 2530239 Status: Offline Thanks Meter: 14 | finally problem solve yhnk you very much infinity team close tread.. Card found : S/N : D817BCB2 , v0130 Chinese Miracle II [MTK module] v 1.44 Load File File_Info : sanstar72_wet_lca FileVersion : MT6572 Load File Ok Operation : Flash [ v1.44 ] ======= Flash Files set for flashing : [ MCU ] : MT6572__SAMSUNG__GT-I9060I__ALPS.JB3.MP.V1__Android_4.4.4.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D00B28C54374F0B Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D00B28C54374F0B [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : F8827405FFD40A18F70DFA86DD633E4A INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : samsung ProdName : GT-I9060I ProdModel : GT-I9060I Device : GT-I9060I AndroidVer: 4.4.4 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 ISPFF ID : 6572 , TARGET ID : 6572 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6572__SAMSUNG__GT-I9060I__ALPS.JB3.MP.V1__Android_4.4.4.ispff Init Ok , Sending blocks ... Write done , 3728 blocks sent Done! Elapsed: 00:09:28 Reconnect Power/Cable! |
