10-28-2015, 14:22 | #1 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2287188 Status: Offline Thanks Meter: 31 | SAMSUNG I9076 MT6572 Too much data! Break! Send report to support NEED SOLUTION Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048600A3879321B3 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600A3879321B3 [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 210 AVVerify : Too much data! Break! Send report to support Error! Check previous message for more info! Check battery, cable, charge! Before try again, check result! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! IF THE TEAM NEED ITS BACKUP I CAN UPLOAD FOR FURTHER TEST |
The Following User Says Thank You to gmt91050 For This Useful Post: |
