11-24-2015, 13:42 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | samsung n9006 clone hang on logo done |
11-24-2015, 13:43 | #2 (permalink) |
Member: 1763380 Status: Offline Thanks Meter: 86 | Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810446EDCBD21B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810446EDCBD21B7 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : ja3gxx ProdModel : SM-N900 Device : ja3g AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1 Done! Elapsed: 00:00:04 Reconnect Power/Cable! Operation : Read Flash [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810446EDCBD21B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810446EDCBD21B7 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : samsung ProdName : ja3gxx ProdModel : SM-N900 Device : ja3g AndroidVer: 4.2.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_mbk72_wet_jb3.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6572 / V1.1.1 / mbk72_wet_jb3 / EMMC FW Size : 737 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\MT6589__samsung__SM-N900__ja3g__4.2.2__ALPS.JB3.MP.V1\ All done! Done! Elapsed: 00:03:25 Reconnect Power/Cable! Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810446EDCBD21B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810446EDCBD21B7 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 24 Removing infected files and scripts ... SmartAV Report : Removed 24 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Format FileSystem [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : FE014E50305858585810446EDCBD21B7 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : [MICRON] , XXXX0 [eMMC] : FLASH_CID : FE014E50305858585810446EDCBD21B7 [eMMC] : FLASH_EXT : 0x00100000 , 0x00100000 , 0x00100000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to den fatih For This Useful Post: |
