10-02-2014, 16:20 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Samsung Orginal E1282t Done With In 2 Mint when press power button show e1282t and off. Mune Button Boot Key Just Format and Problem Solved. Info Logs Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Done! Format Logs. start at : [10/2/2014 / 8:12:38 PM] Operation : Format File System [ v1.00 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 92 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 0000 [0] Flash DIE : 00EF 0060 0018 0000 [0] Flash VEN : Winbond , W25Q128 [0] Flash CAP : 01000000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Regard FullFlashPak |
The Following 4 Users Say Thank You to FullFlashPak For This Useful Post: |
10-03-2014, 13:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Hello, Thanks for report ! And here is list of more supported Samsung models: http://forum.gsmhosting.com/vbb/f296...tware-1864888/ |
10-03-2014, 14:17 | #3 (permalink) | |
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
Any Way Thanks you very much | |
10-04-2014, 07:39 | #4 (permalink) | |
Member: 782530 Status: Offline Thanks Meter: 8,136 | Samsng E1282t Dead recovery with Other Box FlashFile i used This Flashfile http://forum.gsmhosting.com/vbb/9247761-post2.html Here is Write Flashfile Logs and Screen Short Quote:
The Following User Says Thank You to FullFlashPak For This Useful Post: |
