Samsung S269 contact service ?? Phone is locked please contact service center. I solder pic 2 pin3 and gnd. but phone not conected....? COM4 [VCP0] selected module v1.45 Device: Samsung-SCH-S259, S269, S299 operation: Rebuild EFS/NV Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 26 sec |
Check Cable,Check Comport ,Check Weather UR Phone Connected Well Or Not Better Try To Solder Wires On Back Pinout's Already Included In Shell Wbr <<<Megatron>>> |
COM7 [VCP0] selected module v1.49 Device: Samsung-SCH-S259, S269, S299 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... Phone detected, wait... step-1 done step-2 done step-3 done operation finished Finished, time used: 30 sec Sir, this is my result, but still phione shows Phone locked - Please contact service centre Please help me sir |
Follow This 1-Rebuild 2-Unlock Wbr <<<Megatron>>> |
Thanks sir, its worked Hats off to Infinity |
i also same problem phone detect usb port but i cant rebuild plz help |
sir can you tell where i have to solder the wire |
Open Infinity-Box Shell, select model and there you can see image with pinout for rj-45. Br. |
