07-01-2015, 12:41 | #1 (permalink) |
Banned Join Date: Nov 2013
Member: 2058900 Status: Offline Thanks Meter: 177 | Samsung S7562 MTK6575 Factory File 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344702055E6C18502F [eMMC] : FLASH_LEN : 0x00000000E2C00000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... MT657x Old CPU : Skip Initial Info read [Image Ok] : preloader_ztesz75_cu_ics.bin [Image Ok] : DSP_BL [Image Ok] : MBR [Image Ok] : EBR1 [Image Ok] : lk.bin [Image Ok] : boot.img [Image Ok] : recovery.img [Image Ok] : secro.img [Image Ok] : logo.bin [Image Ok] : EBR2 [Image Ok] : system.img [Image Ok] : cache.img [Image Ok] : userdata.img Brand : samsung ProdName : bird75_d_cu_ics ProdModel : GT-S7562 Device : bird75_d_cu_ics AndroidVer: 4.0.4 MTKxCPU : SMDK4210 MTKxPRJ : ALPS.ICS.MP.V2.16 [ScatCFG] : MT6575 / V1.0.0 / ztesz75_cu_ics / EMMC FW Size : 436 MiB Scatter saved to : C:\InfinityBox\CM2MTK\Flash\SMDK4210__samsung__GT-S7562__bird75_d_cu_ics__4.0.4__ALPS.ICS.MP.V2.16\ All done! Done! Elapsed: 00:03:47 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to AdnanSattar302 For This Useful Post: |
