Old 07-01-2015, 14:36   #1 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
samsung s7562 write flash problem help me
Samsung s7562 hang on logo problem
write flash dead
flash erase
init Preloade Failed
plz help me how to solved problem
 User selected Preloader file : preloader_lenovo72_we_jb3.bin
Operation : Init Preloader [ v1.21 ]
 Wait for phone...
Phone found! [ 4 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048600A384A0A06D
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A384A0A06D
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
 SecCfg Passed , 1799
BL : Storage supported by BootLoader!
Sending BootLoader ...
Preloader Init Failed! Looks like HW error or incompatible image
 Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
 Operation : Flash [ v1.21 ]
 ======= Flash
 Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 ScatCFG : BaseBand : MT6572 , Project : lenovo72_we_jb3 , Storage : EMMC
Setting : AFF verify :  Enabled
 BL : Check HW compatibility
BL : Check eMMC compatibility
 BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x00000000E3E00000
Flash Pre-Erase Done, time used : 00:00:22
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_lenovo72_we_jb3.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
 Done!
Elapsed: 00:00:46
Old 07-01-2015, 15:57   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,662
Hello.
Make "Flash Erase" without "Keep Preloader".
Flash after. Post both logs.
Old 07-01-2015, 16:16   #3 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
fast I read this phone flash file don
and
Flash Erase" with "Keep Preloader
read same other working phone file
write backup file or working phone file same problem
 Chinese Miracle II  [MTK module] v 1.21
 Scatter Load Ok , BaseBand : MT6572 , Project : lenovo72_we_jb3 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
 ======= Flash
 Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase : 0x0000000002300000-0x00000000E2D00000
 Done!
Elapsed: 00:00:48
Old 07-01-2015, 16:19   #4 (permalink)
JayDi's Avatar
Member: 462970
I give complete "to do".
If after "Erase Flash" without "Keep Preloader" - phone still show " Preloader status : Alive " - that mean FlashIC come to "ReadOnly" state.
Old 07-01-2015, 16:22   #5 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
and
again flash
 Operation : Flash Erase [ v1.21 ]
User accepted Flash Erase operation!
 Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 Erase Flash now ...
Erase whole flash
Flash erase done
 Done!
Elapsed: 00:00:19
 ======= Flash
 Wait for phone...
Phone found! [ 80 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00A8
DRAM Init Ok , 0x20000000
SOC VERIFY : C1
Boot Ok!
 Switching to HSUSB
HSUSB Init Ok
 Done!
Elapsed: 00:01:21
Old 07-01-2015, 16:24   #6 (permalink)
JayDi's Avatar
Member: 462970
Finally , seen some logs.
Ok, next - try flash this factory FW with SPFlashTool. Will it give some error or not?
Old 07-01-2015, 16:34   #7 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
SPFlashTool
brom error ;??(8)
Old 07-01-2015, 16:42   #8 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
sp flash tool select all memory test method report
 ============ Memory Detection Report ===========
 Internal RAM:
 External RAM:
 Type = DRAM
 Size = 0x20000000 (512MB/4096Mb)
 NAND Flash:
 ERROR: NAND Flash was not detected!
 EMMC:
 EMMC_PART_BOOT1 Size = 0x0000000000200000(2MB)
 EMMC_PART_BOOT2 Size = 0x0000000000200000(2MB)
 EMMC_PART_RPMB Size = 0x0000000000200000(2MB)
 EMMC_PART_GP1 Size = 0x0000000000000000(0MB)
 EMMC_PART_GP2 Size = 0x0000000000000000(0MB)
 EMMC_PART_GP3 Size = 0x0000000000000000(0MB)
 EMMC_PART_GP4 Size = 0x0000000000000000(0MB)
 EMMC_PART_USER Size = 0x00000000e7000000(3696MB)
 ============ RAM Test ============
 Data Bus Test:
 [D0]
 [D1]
 [D2]
 [D3]
 [D4]
 [D5]
 [D6]
 [D7]
 [D8]
 [D9]
 [D10]
 [D11]
 [D12]
 [D13]
 [D14]
 [D15]
 [D16]
 [D17]
 [D18]
 [D19]
 [D20]
 [D21]
 [D22]
 [D23]
 [D24]
 [D25]
 [D26]
 [D27]
 [D28]
 [D29]
 [D30]
 [D31]
 OK!!
 Address Bus Test:
 [A1]
 [A2]
 [A3]
 [A4]
 [A5]
 [A6]
 [A7]
 [A8]
 [A9]
 [A10]
 [A11]
 [A12]
 [A13]
 [A14]
 [A15]
 [A16]
 [A17]
 [A18]
 [A19]
 [A20]
 [A21]
 [A22]
 [A23]
 [A24]
 [A25]
 [A26]
 [A27]
 [A28]
 OK!!
 RAM Pattern Test :
 Writing ...
 0x44332211,
 0xA5A5A5A5,
 0xA5A5A500,
 0xA500A500,
 0xA5000000,
 0x00000000,
 0xFFFF0000,
 0xFFFFFFFF,
 OK!!
 Increment/Decrement Test:
 Writing...
 OK!!
 ============ EMMC Test ============
 EMMC Pattern Test(0x5A5A):
Old 07-01-2015, 16:54   #9 (permalink)
JayDi's Avatar
Member: 462970
Can suggest try write whole memory dump from alive phone.
Old 03-01-2016, 12:39   #10 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Brand : samsung
ProdName : lenovo72_we_jb3
ProdModel : GT-S7562
Device : lenovo72_we_jb3
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
[Read Ok] : preloader_lenovo72_we_jb3.bin
hi..
can u pls share the factory file if u have..?
Old 03-22-2016, 14:20   #11 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Originally Posted by LoveLess View Post
Brand : samsung
AndroidVer: 4.2.2
MTKxCPU : MT6572
hi..
come on guys..
nobody has this fw..? i need it...
Old 03-22-2016, 23:00   #12 (permalink)
Member: 651892
Thanks Meter: 203
Here is your file
MT6572__samsung__GT-S7562__lenovo72_we_jb3__4.2.2__ALPS.JB3.MP.V1
The Following User Says Thank You to danishalnoor For This Useful Post:
Old 03-23-2016, 18:40   #13 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,593
Originally Posted by danishalnoor View Post
thanx alot for file..but device is resetting on startup logo..maybe i need full dump or hw pb..
Page generated in 0.43853 seconds with 8 queries
