04-21-2015, 13:01 | #2 (permalink) |
Freak Poster Join Date: Jun 2006 Location: PAKISTAN.PUNJAB.ATTOCK.JAND
Member: 291071 Status: Offline Sonork: 100.1663377 Thanks Meter: 18 | Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:17 Reconnect Power/Cable! plz help |
04-21-2015, 13:38 | #3 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
04-21-2015, 14:03 | #4 (permalink) |
Member: 291071 Status: Offline Sonork: 100.1663377 Thanks Meter: 18 | Chinese Miracle II [MTK module] v 1.17 User selected Preloader file : preloader_hexing72_wet_jb3.bin Operation : Init Preloader [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:21 Reconnect Power/Cable! User selected DumpFile , extracted : preloader_mbk72_wet_lca.bin Operation : Init Preloader [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501004E35585A4D42019242CCE3C01F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
04-22-2015, 08:30 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 36
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,307 | make a pic of phone back side and upload here i will give you firmware dump |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
