05-12-2015, 19:12 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | samsung SM-G900F can't write security Start at : [5/12/2015 / 12:58:01 PM] Operation : Fix Unknown BaseBand [ v1.20 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 114 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A43D311FDB117 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A43D311FDB117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:27 Reconnect Power/Cable! Finish at : [5/12/2015 / 12:58:28 PM] Start at : [5/12/2015 / 12:58:49 PM] Operation : Repair Security [ v1.20 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 114 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... |
05-12-2015, 22:32 | #3 (permalink) | |
Member: 28559 Status: Offline Thanks Meter: 85 | Quote:
https://mega.co.nz/#!MFUTVbSZ!qrg7KY...S69WYx_SbGvh3k | |
05-14-2015, 18:55 | #4 (permalink) |
Member: 28559 Status: Offline Thanks Meter: 85 | new version 1.2.1 still cant repair security cm2 1.2.1 freezes and cashes . please fix this Start at : [5/14/2015 / 12:38:20 PM] Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A43D311FDB117 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A43D311FDB117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : samsung ProdName : klteskt ProdModel : SM-G900F Device : klteskt AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.13 Done! Elapsed: 00:00:23 Reconnect Power/Cable! Finish at : [5/14/2015 / 12:38:43 PM] Start at : [5/14/2015 / 12:39:04 PM] Operation : Write NVRAM [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [5/14/2015 / 12:39:15 PM] Start at : [5/14/2015 / 12:39:21 PM] Operation : Write NVRAM [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A43D311FDB117 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A43D311FDB117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [NVCheck] : BBID : MT6582 , NVID : MT6582 [NV] : Write Ok! [Info] : NVRAM Repair on erased/damaged phone : 1. Fix Unknown BaseBand 2. Repair Security 3. Write NVRAM Done! Elapsed: 00:01:27 Reconnect Power/Cable! Finish at : [5/14/2015 / 12:40:48 PM] Start at : [5/14/2015 / 12:41:08 PM] Operation : Fix Unknown BaseBand [ v1.21 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A43D311FDB117 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A43D311FDB117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:18 Reconnect Power/Cable! Finish at : [5/14/2015 / 12:41:26 PM] Start at : [5/14/2015 / 12:41:33 PM] Operation : Repair Security [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... |
05-15-2015, 00:08 | #7 (permalink) |
Freak Poster Join Date: May 2009
Member: 1038939 Status: Offline Thanks Meter: 99 | Please wait,upload now... https://mega.co.nz/#!m4YmGTjJ!mHyNqW...MGNPWrn4YMiwIM - flash and repair imei. Last edited by Mumang; 05-15-2015 at 00:16. |
05-15-2015, 00:26 | #8 (permalink) |
Member: 1038939 Status: Offline Thanks Meter: 99 | To JayDi - it is not a phone, but firmware curve, only that the same did come across this subject in the search for just ... Starter accomplish your goal by the result. |
The Following User Says Thank You to Mumang For This Useful Post: |
05-15-2015, 03:28 | #9 (permalink) | |
Card found: S/N 0197:0128 Chinese Miracle II [MTK module] v 1.21 Operation : Fix Unknown BaseBand [ v1.21 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034473A43D311FDB117 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034473A43D311FDB117 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Reset Done! Done! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Repair Security [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 136 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6582, E01 HW : ZX82_WET_JB5_HSPA_HW SW : MOLY.WR8.W1315.MD.WG.MP.V15 MM : 2000.00.00 VR : 1.0 Security Info : IMEI [1] : Damaged! IMEI [2] : Damaged or not exists Read Ok! Update IMEI[1] to : 353296060106066 done! Done! Elapsed: 00:00:55 Reconnect Power/Cable! | |
