Old 03-06-2016, 11:13   #1 (permalink)
omi17's Avatar
Member: 1950912
Sonork: 100.1654643(Offline)
Thanks Meter: 398
SAMSUNG SM-N9006 COPY PreLoader Not Active need help!!
Hi Supporters,
Got one copy Samsung Note SM-N9006,
History as per customer told-
Monkey Virus problem > Flashed with flashtool probably wrong file> dead
Here is CM2 Logs-
Operation : Check / Read Info [ v1.42 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 45010053454D3034473AFAAE77225255
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473AFAAE77225255
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : 069B521D885980A086FD2F9DA24D3880
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:27
Reconnect Power/Cable!
Here is back sticker photo-
Kindly help to revive> need working flash file (tried nearly all files for note SM-N9006 available at needrom)
Old 03-06-2016, 12:13   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
Hello. Only trying all available flash files from similar models. If mobile NOT flashed with alied FW - you can read it info by enable additional options with "Identify" button.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-06-2016, 12:18   #3 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,240
try this one
note 3 n9006 mtk6572 - Download - 4shared
password is "www.dostgsm.com"
The Following 2 Users Say Thank You to Nasir Mobiles For This Useful Post:
Page generated in 0.18899 seconds with 7 queries
