Old 10-26-2016, 06:34   #1 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Samsung_G530H MT6572(GALAXY_Grand_Prime) Flash Done With CM2
Scatter Load Ok , BaseBand : MT6572 , Project : keytak72_cwet_lca , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Samsung
Device Model   : Samsung G530H(GALAXY Grand Prime)
Device CPU     : MT6572
Device IntName : SM-G530H
Device Version : 4.4.2
Device Compile : 11/18/2015 9:53:16 AM
Device Project : ALPS.KK1.MP7.V1
Device ExtInfo : SM-G530H
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 1101003030344739301013D0AFBA20C5
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 1101003030344739301013D0AFBA20C5
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID    : 0xC3555188858B16F170719DAFFB0B5FE6
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : keytak72_cwet_lca , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3815 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:01
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_keytak72_cwet_lca.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:25
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:37
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
Reconnect Power/Cable!
The Following User Says Thank You to .::Mustafa::. For This Useful Post:
Old 10-26-2016, 07:56   #2 (permalink)
Member: 2564979
Sonork: khalidartist
Thanks Meter: 22
Originally Posted by .::Mustafa::. View Post
Samsung_G530H MT6572(GALAXY_Grand_Prime) Done With CM2
Files found : 11 , Set to  : 10
Device Brand   :
Device Model   :  G530H( Grand Prime)
Device CPU     : MT6572
Ready to !
Operation :  [ v1.58 ]
1. Power Off  , Remove battery , Insert back
Wait for ...
 found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
NAND  : NOT INSTALLED
eMMC  : 1101003030344739301013D0AFBA20C5
SOC VERIFY : C1
Boot Ok!
Setting :  Pre-Erase (Safe) : Enabled
BL :  Pre-Erase
PartCount : 0013
Repartition Done!
Use FLN Mode
Processing :  Write
 now : MBR
Image  Ok
 now : EBR1
Image  Ok
 now : UBOOT
Image  Ok
 now : BOOTIMG
Image  Ok
 now : RECOVERY
Image  Ok
 now : SEC_RO
Image  Ok
 now : LOGO
Image  Ok
 now :
Image  Ok
 now : CACHE
Image  Ok
 now : USRDATA
Image  Ok
Processing : Verify
Verify Passed : MBR
Verify Passed :
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
please share your file thanks in advance
Old 10-26-2016, 09:36   #3 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Old 10-28-2016, 05:45   #4 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
Sir i have a many Good and tested file but After Compress File Size Is To Large Problem To Upload.
If u have ha File Compress Software Please Share with Me
thanks In Adavance
Regards::.
.::Mustafa::.
Old 10-28-2016, 07:03   #5 (permalink)
Member: 1406155
Thanks Meter: 38
Brother please say how sam mtk format by cm2 means the boot key to conect computer.thanks.
Old 10-28-2016, 08:07   #6 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 261
brother try
vol+
vol-
vol up+ Down
Home Button on android mobile
(On Key paid)
Call
Menu
8+5
same Model Back Botton
Old 10-28-2016, 12:56   #7 (permalink)
Member: 1406155
Thanks Meter: 38
Then how u flash sam g530h, vol- or vol+ please explain,thanks.
Old 10-28-2016, 18:19   #8 (permalink)
Member: 651892
Thanks Meter: 205
thanks In Adavance
Regards::.
.::Mustafa::.
Use This Free Software for High compression...
7-Zip
Page generated in 0.19275 seconds with 8 queries
