08-07-2008, 12:04 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | << LG KG 271 Unlocked successfully By Infinity >> Thanks Infinity Team >>>> Device: LG-KG271 Checking data, wait... Action: unlock direct unlock method #2 (Airtel etc.) Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... sw version: ULC2GL BSNL KG271 P16 FL 91 V10a 404-66 JAN 29 2008 +0 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG271_eeprom-sta_20080807-151329.B1E.bin loading data... data loaded imei: 35617601994588800 reading [eeprom-sec_ Infinity....]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG271_eeprom-sec_Infinity...._20080807-151331.B1E.bin reading [eeprom-complete_Infinity....]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KG271_eeprom-complete_Infinity...._20080807-151333.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-sec Writing: eeprom-sec probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 19 sec |
The Following User Says Thank You to zeel_zeel For This Useful Post: |
<< F3 unlock success with Infinity >> | zeel_zeel | Infinity-Box | 16 | 01-11-2012 21:32 |
LG KG245 unlock successfully by infinity | kmaxmax | Infinity-Box | 1 | 05-13-2009 06:52 |
LG KE970 unlock success by infinity | jakoy | Infinity-Box | 3 | 07-21-2008 16:05 |
J100 Unlock Successfully By Infinity. | debmobile | Infinity-Box | 1 | 07-05-2008 09:58 |
<< CE110 and KE500 unlock successful with FG >> | zeel_zeel | FuriousGold | 0 | 05-07-2008 11:41 |
